Multi-Computer, Single Server
Add the ability to host the server on two separate computers on the same network. I think if it could recognize that the server is being set up on the same network(IP) then it should give us the ability to connect it to the same server. Giving the ability to split the workload to two separate machines. Or even if it was outside the network. Image how this would benefit larger Plex servers.
This is a duplicate request. The ability to distribute workload (“load-balancing”) has been requested before.
Can you link to an active request. I found many people talking about this feature for years but typically don’t go anywhere or taken seriously.
All feature request threads are “active”, as long as they are not closed.
That’s sad :frowning: one from 2014 and another from 2015. So basically we should make more :stuck_out_tongue:
Nope. I will close duplicates.
