Multi plex server for transcode
Server Version#: 1.18.2.2029
Player Version#:Version 4.8.4
French version bellow
#english#
Hello,
Just a question, if I want to use multiple server for helping on the transcoding, do you know if you have a “farm” version where I have 1 master managing the Library, and use différents " satellite" to help the main one to transcode whe distant user are playing a movie ?
Thank you :slight_smile:
#french#
Bonjour
Juste une simple question, est-il possible d’utiliser plusieurs serveurs pour aider au transcode.
Savez vous si un mode “Ferme” est possible ou un serveur central centralise la bibliothèque et en fonction de la charge du CPU, utiliser différent “satellite” pour décharger le central quand un utilisateur demande un file à distance en transcode
Merci :slight_smile:
Plex does not cluster nodes for transcoding.
There are setups out there that does some of what your asking. But they are not part of Plex.
a google search will help you find them.
