Multi rooom audio topic
Hi peeps … I need advice i own 2 amazon Alexa and only have the ability to stream music on both of them at the same time using spotiy
I need to know what should i rather invest in or move over to sonos or google ? or go all the way out and raspberry pi everything ?
I basically need :
  • to play music every where at the same time
  • control everything form my phone
If only i we could add plex as a music service on amazon then life would be easier …lol
what hardware are you using ?
Unfortunately Amazon doesn’t allow custom skills like Plex to make use of grouped speakers. This applies to Alexa-powered Sonos Ones as well.
Using Plex for Sonos you’re able to setup speaker groups and migrate music playing between them or group them all together. You can use the Sonos app for playback and grouping, and you’re able to use the Plex app directly to cast music to any Sonos group.
