Multiple Homerun Connect with plex
How to run 2 HDHomeRun connect with PLEX.
BILL
I haven’t done it personally, but don’t you just need to add the second tuner by accessing your server settings, selecting “Live TV & DVR” (on the left, towards the bottom, under “Manage”), then clicking the “+ Add Device” button that is located under the listing for your existing tuner?
thanks
I have 2 Primes on mine. All you have to do is add device twice. Hopefully they are the same type. I had issues when I had a connect and a prime.
