Multiple Users and RasPLEX
Hi All,
I've recently setup PMS on a PC running Ubuntu.  After reading about PlexPass and specifically PlexHome (user permissions) I decided to pickup PlexPass.
I've installed RasPLEX on one of my Pi's, but am unable to find a way to switch from the master profile to the specific user with limited libraries.
Basically, I want a profile for myself (Adult) with access to all movies/shows and a separate profile for the kids with access to a limited set of child friendly libraries.
Any help would be appreciated.
It will be released as the developers incorporate the new versions of PHT... there is a flowdown of the features, as PHT/PMS release new features each client needs time to then incorporate the code.  Right now only PHT and web clients supports home users, its a bleeding edge feature.
I follow this forum pretty closely and have not seen a timeline on the next version yet.
Thanks for the quick reply.
Has multi user been implemented yet? I don’t want to install Beta builds unless there’s no other way :confused:
Has multi user been implemented yet? I don't want to install Beta builds unless there's no other way :/
Yes, Plex Home was implemented in 0.5.0, current release is 0.5.1, but a more stable build should be released in the next couple of days - 0.6.0 - for both the RPi1 and RPi2.
Regards
Thanks, I’ll wait for the stable release if it’s only a few days away. Thanks very much!
