Server Version#: 1.24.3.5033
Player Version#: HTPC, Plex Media Player, and Web - all most recent versions
Server: Intel NUC NUC 10 NUC10i7FNH, 16GB RAM
Lifetime Member
Internet: Gig (800-850 real-world speed)
LAN: Gig connection Server → router
I’m unsure if I placed this into the correct category so if not, please move the post as needed (apologies!). Also, I’ve searched quite a bit and can’t seem to find what I’m looking for.
I have quite a few 4k items and plenty of 1080 (high and lower bandwidth versions) and typically will create 1080 and 720 versions for the 4k items. My naming convention for multiple versions of the same movie is (all located adjacent within the same folder):
Awesome Movie (2021) -2160.mkv/mp4/etc
Awesome Movie (2021) -1080.mkv/mp4/etc
Awesome Movie (2021) -720.mkv/mp4/etc
I know the “automatically adjust quality” feature works and does a great job when I am remote however, I thought if you had a 4k version and a 1080 version of the same title the server would offer either depending on the reported capabilities and available connectivity. I can always select “Play Version” however, I thought the system would automatically play the version closest to your capabilities.
Ex: At home on my 4k system I hit play and it serves up the 4k version as evidenced through the system status and Tautulli. On my 1080p FireTV if I hit play it begins transcoding the 4k version down to 1080 and if I’m at my other place with Roku with crappy internet it’ll transcode the 4k to 720 which is not a fun experience. I thought it would offer the 1080 or 720 versions based on the player’s capabilities. Is this correct or am I misunderstanding?
If I wish to play the 1080 version of a title on my Windows-based bedroom player (Plex HTPC) I must use the “Play Version” option otherwise it begins transcoding down from 4k.
I’m not sure if there is a specific log I should cite but if so, let me know and I’ll run a test.
I also read somewhere the audio codec may cause certain things to happen therefore, all the 1080 and 720 versions of a 4k title have AAC as the first option with a second sometimes available as Auto-Passthrough but only for those with TrueHD/Atmos tracks.
I have also noticed that for those titles that I used the Plex Media Optimizer the lowered quality version was not selected automatically. I usually use the Optimizer for converting 1080 down to 720 and Handbrake for 4k to 1080.
I’ve searched and have not been able to locate another thread on this topic but if there is one please kindly point me that way - not quite sure which search terms to use or if I am simply misunderstanding how the process works.
Thanks in advance!
