Can You add the fast and back forward fro the music player on apple tv, it’s realy missing!
Also can ytou use the same filter possibility as the computer (pc and online) app because i rename and classified all my songs and apple tv app dont use it!!!
The music part is really really bad on apple tv!
As far as I know you would have to use custom player for FF RW functionality as Apple does not support it, you can only skip to previous/ next song.
EDIT: No, scratch this. It IS supported via bottom progress bar.
Hello!
We are working on that feature but it won’t be available in version 1.3. We’re aiming to include it in 1.4
@sergiou87 said:
Hello!We are working on that feature but it won’t be available in version 1.3. We’re aiming to include it in 1.4
Now that we can play music in the background while navigating through plex, will features like Play Next and Add to Queue be added? Maybe in the 1.4 update?
No plans for them yet, but they will eventually be included in the app, hopefully sooner than later
To be able to add music to playlist will also help
