Music/Itunes/Lyrics/ID3
Have come back since a long time to see what plex has evolved into.
Being slightly dissapointed about the hard no-gos that drove me away (although plex lifetime subscriber) still there:
  • Itunes smart playlists don’t import even if you put your path to the library file, or export playlists. Don’t push me to edit the XML file, thank you. (Fix this please)
  • LyricFind doesn’t even begin to work although in the agent settings at the top an checked and a library refresh. (Fix this please, as it also is a announced feature!?)
  • If you can’t fix Lyrics, please support ID3 finally, because my Library is full of Lyrics, that are not picked up by Plex. TY in advance.
Michael
I already tried to edit the xml file given the manuals in this forum for hours. Doesn’t work.
Rebuilding my work of almost two decades, no thanks. I’ll keep ITunes/Music around, since it simply does the job.
No. I sincerly don’t have to start there. I finished it a long time ago and have checked my entrances with various online sources over the years (CDDB/Discogs etc. etc.) No need to scold me here. It took me almost 20 years to come to this place.
So, even those lyrics are not picked up. And yeah, its the Itunes style of filing. So you tell me to change 20k files so they just fit into Plex? Why doesn’t it work with what is already there, and changes it by it self to fit?
Greetings Michael
(my apologies if this gets a little heated but i really am frustrated)
PS: Please tell me or link me to sth. that i haven’t yet seen about LyricFind. Maybe i have some freaky settings or sth.
My bad it seems.
That’s the only reason i tried to edit it in the first place. Since there is no way, I’ll give up on that.
Settings haven’t been changed before or during this discussion.
Check it out: 01 Back and Forth.txt (1.4 KB)
No DRM in my library. That is for sure. CD/Apple Lossless created by XLD/EAC Accuraterip.
Library was created with latest release (as i said i wanted to check what plex has new to offer)
I will check your support article.
Thank you
I have to say thinking about your organization tips, i will give it a shot and change one album to see if there will be a desired outcome.
The files are stored on a NAS and they are copied from the Mac. Path is the following:
NAS (Synology):
Mike
Plex (Plex Server set this up, no media files in here)
Root: MikeDS (volume1/)
/Mike/Plex/05 Musik/ITunes/ITunes/Music
The double “Itunes” stems from me backing up the complete music folder since Apple had the audacity to change to “music”-app without a new library.
Plex already had R/W to all folders but nevertheless i have redone R/W rights and switched them back for all folders/subfolders/files for the user plex. Have a look at this:
This could already be the end of story, because i can pull all the lyrics from the tags with “LyricsFinder”-App for mac and save them in the appropriate folders as txt.
Does plex need admin rights to use Plex LyricFind?
Lyric find now also does work for me: (no added .txt lyrics on this album)
Thank you so very very very much.
This makes me so enthusiastic, i’ll recreate the smart playlists in plex (since there will nothing be added as they are release-time based)
Greetings from Germany
Michael
