Hi everyone,
I have a plex server via Synology and I am desperately trying to have the music library specifically and ONLY used with the embedded tags that I have myself filled in via iTunes. Unfortunately, even following the instructions and un/ticking all the options it doesn’t work AT ALL! As easy as it is, all the music is considered as [Untitled music] - [Untitled tracks] and that is quite insane!
I do not want to use Plex Pass Premium as it does not meet my requirements and I feel a little helpless here.
Is there anything I should do or that I forgot to do here?
Thanks a lot for your help.
Cheers,
Claudio
Well, which instructions did you follow?
When you created the music library, did you decline the offer to create a Premium library?
In which order do the lines appear under
Settings - Server - Agents - Albums - Personal Albums
and under
Settings - Server - Agents - Albums - last.fm
(‘Local Media Assets’ should be active and in top position)
Which primary agent is selected under the properties of your music library (‘Advanced’ tab) ?
https://support.plex.tv/articles/200289266-editing-libraries/
What file format are you using for your music?
Here are some tips regarding music
multi-disc albums
https://forums.plex.tv/discussion/comment/1050849/#Comment_1050849
handling singles and EP’s
https://forums.plex.tv/discussion/comment/1093611/#Comment_1093611
possible ‘side car’ files for music
https://forums.plex.tv/discussion/comment/1319703/#Comment_1319703
soundtracks and ‘various artists’
https://forums.plex.tv/discussion/comment/1472799/#Comment_1472799
