Music Library Doesn't Get Artist or Album Artwork
I am getting the same thing with Plex seeing the first album. I did an experiment and pointed it to my iTunes directory which is organized by artists and albums and Plex organized that correctly.
I think I will just use Plex for movies and TV shows from now on and see if other alternatives for music exists like HifiBerry OS or so.
I hope the Plex developers are reading this. Why break something that was working before? At least they should’ve given us an option instead of yanking a feature away.
Agree … one more thing I’m going to play with is to see if I can force plex to use just “local media” for the track and grouping piece. All the system needs to do is read the ID3 tags … which is all I want it to do.
I have this same problem too. Why in the world is it still not being fixed in this day and age?!
Excuse my ignorance, but how can I fix ownership and permissions on the host directory?
That would depend on what OS/System your Plex Media Server is running on, but in the case that you are running on linux:
chmod og+rw -R <dir>
Substituting your desired directory for <dir>, this command will apply read/write permissions to <dir> and all of its contents recursively, to the user and group who own the files.
Not that I think Plex is perfect, but I have to add my support here for the way it operates in this regard. A few things:-
Computer filesystems work more efficiently with structured storage and fewer numbers of files in any single folder. Simply throwing more than a thousand files into a single folder is just not good practice. Daft in fact. If nothing else, forces you to modify file names just to avoid duplications and makes maintenance a nightmare.
Plex works in a certain way with regard to cataloguing media files and associated metadata and if you follow its rules, it works. I am normally averse to software that insists I abide by its rules rather than it being able to work with how I want to do it, but in this case, Plex has got it right. Music media storage SHOULD be structured in this way, not just for Plex’s benefit. I cannot imagine anything worse than struggling with over a thousand media files in a single folder/directory. Madness.
I have over 25,000 music files and I have repeatedly created Plex libraries that now faultlessly import all those files, read their metadata and associated artwork files and add other interesting data from Internet sources. As I said, repeatedly. In an effort to achieve exactly what I want, I made some adjustments to the metadata to establish what works for me in both iTunes and Plex.
In my experience it is incorrect to state simply throwing thousands of music files into a single folder is some sort of industry standard. It is no such thing. Some software may deal with it as you want, but when I have tried this on a small scale, the player (most recently a Sony in car head unit) just plays each file in some order it decides and makes NO attempt whatsoever to read the metadata and present a structured view to the user. Give me Plex in the car.
So, don’t try and throw lots of files in a single folder and then complain that doesn’t work well in Plex. Just DON’T DO IT. It has been repeatedly stated here, even in this very thread that it’s a bad idea and is likely to not work. So why keep insisting on doing it. Who was it said the definition of insanity was to keep doing the same thing and expecting a different result. Plex has changed and it no longer does what you want, but that wasn’t good practice anyway (for multiple reasons as explained). This is NOT A BUG. Plex now places greater importance on music files’ storage structure, but this is what you should be doing anyway and there are multiple programs that can easily create this structure for you so it’s not even hard to set it up in the first place.
In this instance, Plex does a great job. The problem is not with Plex.
Less politely, stop whining about how Plex doesn’t do what you want. You have been repeatedly told what is required in order to achieve what you want and in any case, that is the best way to do it. If you refuse to comply, it ain’t gonna work for you. Simple as that. So JFDI.
@UKenGB - I appreciate the reply, but you spent a lot of words missing the point that Plex has two ways to capture metadata: Via the ID2/ID3 tags and via the file/directory structure. The feature that many people count on to capture metadata via tags is broken.
It’s documented. It’s supported. And two major versions ago it broke.
And yes, throwing lots of well-tagged files into a single folder is a reasonable use case - which is why most audio streamers on the market fully (and deliberately) support it.
So while the file structure detection method works well for you, it doesn’t mean that the critical metadata-based method so many others depend on isn’t broken and needs to be fixed.
In fact you rather missed MY point. I care not for any ‘structure detection method’. My media is fully tagged and I expect that to be read and used. However, throwing huge numbers of files into a single folder is as I said “BAD PRACTICE”. We all know it doesn’t work well for Plex and I added to that the fact that file systems don’t work efficiently like that as well as pointing out the obvious, that it makes maintenance a nightmare. So with those restrictions in mind, why do you insist on trying to do it ‘your way’ when that is clearly and obviously the WRONG way.
You’ll just get a sore head and the brick wall still ain’t gonna fall down.
I am so sick of this - sick of paying for a media server that can’t read perfectly good tags. All of my music is tagged correctly and has album covers, yet Plex can’t do what hundreds of free media apps have done for decades: READ THE TAGS AND BE DONE WITH IT! I have read every “workaround” and tried every suggested setting.
Today I was “doing cleanup” and found this nightmare “album”:
It shows a Donny Iris Cover
The artist is listed as “10cc”
The album name “Never Run Never Hide” is a Benny Mardones album
It has over 600 songs that I can’t “split” or resolve by telling the program to simply re-read that tags. The only solution is to edit all 600+ by hand or dump and rebuild the Plex Media Folder - AGAIN
WFT? I paid over $100 for this???
Pathetic.
Making thousands of folders for files that already contain all the pertinent information is not progress, it’s redundant nonsense.
I completely agree with Lyman… What the hell, we paid about 100€ for a Plex Pass… I run it on a server where there’s 0 issues with computing power or RAM and I can’t do what I want for my music library??
I used to manage my music with artists folder long time ago, but everything was a mess IMHO.
I’m a DJ and I decided to catalog my music using years and “custom” genres/moods. Something like this:
2021
2021>Dance
2021>Electro-House
2021>Pop
2021>House
2020
2020>Dance
2020>Electro-House
2020>Pop
2020>House
I won’t go back for sure to something that was a nightmare for find a track with similar mood or have bugs like “Avicii” “Avicii & Aloe Blacc” Avicii, RITA ORA" … Tags are made for be readed from software and leave the folder organization to the user
All my library use null character as multi-tag separator (and is an officiall feature introduced in Novembre 2000 [read Wikipedia if you don’t trust me]) and I am obliged not to use Plex for music thanks to these bugs.
Plex really rocks for movies, but for music is not what I expected from a cool library managment software/server.
So you’re not a believer in the filing cabinet then and prefer to store all your paperwork in one big box?
So you don’t agree with everything in one folder then.
Lemme say I’m “in the middle”. I don’t like use folders for every artist but I also don’t like put literally everythng in just one folder.
I use many folders where I store a lot (but usually < 400 files) of different artist’s music. Something like around 30 folders (that are for the genre/mood) for every year.
Okay, maybe my english is too bad for make understand how I manage my music, but really, I want never go back to the artist-folder structure for all my complete music library.
Maybe only for a few artists (max 3/4) that I really follow if I have the entire released songs (like Avicii), but there’s no sense to do it with every artist I listen for few tracks.
