This has been happening for a while now to the point I can’t even use Plex to play music as it is too frustrating.
It takes minutes to start a song if you’re lucky enough to get it started. When you do get it started, it will frequently stop when going to a new song, but if you forward/back you can get it to play something else sometimes. This has been happening for a while now and I have spoken with others who have the same issue.
Is there a fix coming out for this or at a workaround?
@Drek7ng said:
What Device are you having this issue with coz mine is the same on web player and fire tv on my android phone its fine
Hope there is a fix soon cos its totally unusable.
I am using an iPhone 6S+ most of the time. Sometimes it works, most of the time it can take 1-3 minutes to even start a song. Doesn’t matter if I am using it remotely, or on local WIFI.
Any update on this thread? My iPhone 7 (iOS 10.2) is unusable and this is the primary reason I went to PLEX - for remote access to music via steaming. ISP connection a non-issue. Most irritating!
