My first recorded live TV not streaming
Server Version#: Latest version on Windows 11 pro no Malwarebytes
Player Version#: All tablets, smart phone and Samsung TV 8000 series upto date versions
Tuner Make/Model: HDhomerun Prime 3 tuners Comcast Cable card
Guide/Lineup name:
Using XMLTV?: NO HDhomerun
Channel number/Name: 808 NBC
Recorded the Ohio game with commercials removed. Conversion to MP4 I have P2200 card. It plays on the same PC using VLC or PLEX Server with no issues. Will not play on any other device playback error on tablets, and smartphones. The Samsung TV and FireTV it Sits there looking STUPID.
Well, this weekend was a BUST ! All DVR scheduled TV show recordings are handled by MCE . But they are sent to my DVR drive. I use PLEX for a Football game to watch with the family later since I am not keeping it . Boy, do I look foolish !
Plex Media Server Logs_2023-09-25_19-15-23.zip (4.8 MB)
Log
I did some perusing through your log file and I found:
Error while decoding stream #0:1: Invalid data found when processing input
Error while decoding stream #0:1: Not yet implemented in FFmpeg, patches welcome
I searched each of those errors. I cam across this post in Reddit and think you could give it a try.
  1. Shutdown plex
  2. Navigate to Plex’s appdata and locate the codec folder (on mine, at /{appdata}/plex/Library/Application Support/Plex Media Server/Codecs )
  3. Delete the contents of this folder
  4. Restart plex
  5. Plex should automatically download required codecs on start. If not, it will download them when needed.
Here is the link: Reddit - Dive into anything
Hopefully this can fix things for you :slight_smile:
If not we’ll try something else.
To find your appdata directory check out this Support Article:
https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/
Thank you everything is working !
