My Passport Wireless Pro - Error Seeking File Offset
Server Version#: v1.24.3.5033-757abe6b4 - Western Digital My Passport Wireless Pro armv7l - build: linux-armv7hf
Player Version#: Any
tldr; Plex on WD Wireless Passport Pro (busybox based) shows files as “Unavailable”.
May or may not be related to encode profile.
Exhaustively tested various encode profiles without any consistent pattern.
Shorter clips and/or lower bitrates appear to work more often.
Seek error happens at 65536 bytes from end of file.
May be filesystem/mount problem.
Some of the encodes I’ve added have shown up as “Unavailable”.
These very same files work perfectly fine on my Synology NAS.
Initially I thought it may be a compatibility issue with codecs but I’ve gone through literally dozens of combinations from mkv/mp4 containers, aac/ac3/passthrough audio, hevc/h264/nvenc hevc video alongside various custom params and crf/abr settings etc.
Occasionally a particular config will work but most of the time it doesn’t.
I’ve noted that files tend to work if they are of shorter length and/or lower average bitrate. eg. a file will work encoded @ 4096k abr but not work @ 8192k abr.
However, there are files encoded with bitrates of 16M+ that work fine.
Everything has been encoded through handbrake v141 and v131
I’m beginning to think the issue may lie in the file system or some quirk with how WD has setup their mounts/caching.
What’s peculiar is that the seek error offset tends to be exactly 65536 bytes from the end of the file.
Additional info/troubleshooting steps:
  • factory reset
  • same issue with 1.24.4.5081-e362dc1ee
  • file permissions (777) and owner are fine
  • plex is run as root by default
This post from 2016 appears to be talking about the same issue:
My Passport Wireless Pro problems
Oct 04, 2021 17:28:29.748 [0xb6e7ddcc] ERROR - Error seeking in file to offset 7815224769 - 0
Oct 04, 2021 17:28:29.748 [0xb6e7ddcc] ERROR - Exception computing file hashes: Error reading block from /shares/Storage/Plex/Movies/Test/Pirates.of.the.Caribbean.On.Stranger.Tides.2011.1080p.m4v
Full Analysis Log
Oct 04, 2021 17:28:29.028 [0xb428dd50] INFO - Plex Media Scanner v1.24.3.5033-757abe6b4 - Western Digital My Passport Wireless Pro armv7l - build: linux-armv7hf - GMT -07:00
Oct 04, 2021 17:28:29.029 [0xb428dd50] INFO - Linux version: 1.04.17, language: en-US
Oct 04, 2021 17:28:29.029 [0xb428dd50] INFO - Processor Arm
Oct 04, 2021 17:28:29.029 [0xb428dd50] INFO - /usr/local/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix  Analysis --item 170
Oct 04, 2021 17:28:29.003 [0xb6e7ddcc] WARN - Preferences: invalid default value: FSEventLibraryUpdatesEnabled=1
Oct 04, 2021 17:28:29.003 [0xb6e7ddcc] WARN - Preferences: invalid default value: FSEventLibraryPartialScanEnabled=1
Oct 04, 2021 17:28:29.010 [0xb6e7ddcc] VERBOSE - [FFMPEG] - Rescanning for external libs: '/usr/local/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/be22e26-4019-linux-armv7hf/'
Oct 04, 2021 17:28:29.010 [0xb6e7ddcc] VERBOSE - [FFMPEG] - Loading external lib /usr/local/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/be22e26-4019-linux-armv7hf/libhevc_decoder.so
Oct 04, 2021 17:28:29.011 [0xb6e7ddcc] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Oct 04, 2021 17:28:29.738 [0xb6e7ddcc] DEBUG - It took 20.000000 ms to retrieve 123 items.
Oct 04, 2021 17:28:29.746 [0xb6e7ddcc] DEBUG - Analyzing media parts for item 170 (Pirates of the Caribbean: On Stranger Tides): 405
Oct 04, 2021 17:28:29.748 [0xb6e7ddcc] DEBUG - [ID 405] Media part analysis: /shares/Storage/Plex/Movies/Test/Pirates.of.the.Caribbean.On.Stranger.Tides.2011.1080p.m4v
Oct 04, 2021 17:28:29.748 [0xb6e7ddcc] DEBUG - [MI] Opening input file: "/shares/Storage/Plex/Movies/Test/Pirates.of.the.Caribbean.On.Stranger.Tides.2011.1080p.m4v"
Oct 04, 2021 17:28:29.749 [0xb6e7ddcc] DEBUG - [FFMPEG] - Opening '/shares/Storage/Plex/Movies/Test/Pirates.of.the.Caribbean.On.Stranger.Tides.2011.1080p.m4v' for reading
Oct 04, 2021 17:28:29.749 [0xb6e7ddcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 04, 2021 17:28:29.751 [0xb6e7ddcc] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Oct 04, 2021 17:28:29.751 [0xb6e7ddcc] DEBUG - [FFMPEG] - ISO: File Type Major Brand: mp42
Oct 04, 2021 17:28:29.751 [0xb6e7ddcc] ERROR - [FFMPEG] - moov atom not found
Oct 04, 2021 17:28:29.751 [0xb6e7ddcc] VERBOSE - [FFMPEG] - Statistics: 65536 bytes read, 3 seeks
Oct 04, 2021 17:28:29.752 [0xb6e7ddcc] ERROR - Exception analyzing media file '/shares/Storage/Plex/Movies/Test/Pirates.of.the.Caribbean.On.Stranger.Tides.2011.1080p.m4v' (Could not parse /shares/Storage/Plex/Movies/Test/Pirates.of.the.Caribbean.On.Stranger.Tides.2011.1080p.m4v (error=-1094995529): Invalid data found when processing input)
Oct 04, 2021 17:28:29.752 [0xb6e7ddcc] ERROR - Failed to successfully analyze part 405.
Oct 04, 2021 17:28:29.780 [0xb6e7ddcc] DEBUG - It took 20.000000 ms to retrieve 123 items.
Oct 04, 2021 17:28:29.786 [0xb6e7ddcc] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Oct 04, 2021 17:28:29.787 [0xb6e7ddcc] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Oct 04, 2021 17:28:29.791 [0xb6e7ddcc] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/library/changestamp
Oct 04, 2021 17:28:29.792 [0xb6e7ddcc] DEBUG - Updating metadata item (save) (Pirates of the Caribbean: On Stranger Tides) with ID 170
Oct 04, 2021 17:28:29.803 [0xb6e7ddcc] VERBOSE - Skipping expensive tags write for 'Pirates of the Caribbean: On Stranger Tides' (type: 9) since nothing changed.
/sbin/intlmount.sh
#!/bin/sh
source /etc/power.conf
devstr=$1
destdir=/media
dev=${devstr:0:3}
ishddrive=1
isCacheEnabled=0
CacheModName=pmxcache
check_pmxcache(){
    lsmod | grep -q "pmxcache"
    if [ $? -eq 0 ]; then
        lsmod | grep -q "pmxfs"
        [ $? -eq 0 ] && isCacheEnabled=1
    fi
connect_alert_database()
    HDDSpace=`df | grep /DataVolume | awk '{print $4}'`
    if [ ! -d "/CacheVolume/.wd-alert" ] && [ $HDDSpace -lt 1124000 ]; then
        if [ ! -d "/media/sdb1/.wdcache" ]; then
            rm -rf /CacheVolume
            rm -rf /var/tmp
            ln -sf ../tmp /var/tmp
        fi
    else
        checklink=`ls -l /CacheVolume | grep "/media/sdb1/.wdcache" | wc -l`
        if [ "$checklink" == "0" ] && [ $HDDSpace -gt 1124000 ] ; then
                mkdir -p /media/sdb1/.wdcache
            fi
            mv /CacheVolume/* /media/sdb1/.wdcache/
            rm -Rf /CacheVolume
            ln -sf /media/sdb1/.wdcache /CacheVolume
        fi
    fi
    if [ ! -d /etc/wd-alert ]; then
        mkdir -p /etc/wd-alert
    fi
    if [ -L /CacheVolume/.wd-alert ]; then
        checklink=`ls -l /CacheVolume/.wd-alert | grep "/etc/wd-alert" | wc -l`
        if [ "$checklink" == "0" ]; then
            rm -Rf /CacheVolume/.wd-alert
            ln -sf /etc/wd-alert /CacheVolume/.wd-alert
        fi
    else
        if [ -f /CacheVolume/.wd-alert/wd-alert.db ]; then
            cp /CacheVolume/.wd-alert/wd-alert.db /etc/wd-alert/
        fi
        if [ -f /CacheVolume/.wd-alert/wd-alert-desc.db ]; then
            cp /CacheVolume/.wd-alert/wd-alert-desc.db /etc/wd-alert/
        fi
    fi
my_check()
    if [ $ishddrive -eq 1 ]; then
        fstype=`blkid /dev/$1 | sed -n 's/.*TYPE="\([^"]*\)".*/\1/p'`
        echo "${PPID} FStype $fstype on $1" >> /tmp/automount.log
        if [ "$fstype" == "exfat" ]; then
            if [ ! -f /tmp/StartupHDDChecked ]; then
                chkexfat -f --safe /dev/$1
                result=$?
                echo "Quick Testing Result on $1: $result"
                touch /tmp/StartupHDDChecked
                if [ "$result" != "1" ]; then
                    echo "${PPID} exFAT Quick check Failed" >> /tmp/automount.log
                    chkexfat -f /dev/$1
                else
                    echo "${PPID} exFAT Quick check Passed" >> /tmp/automount.log
                fi
            fi
        fi
        if [ "$fstype" == "ntfs" ]; then
                chkntfs -f --safe /dev/$1
                result=$?
                if [ "$result" != "252" ]; then
                    if [ "$result" == "1" ];then
                        echo "${PPID} NTFS Quick check Passed" >> /tmp/automount.log
                    else
                        echo "${PPID} NTFS Quick check Failed" >> /tmp/automount.log
                        chkntfs -f /dev/$1
                    fi
                else
                    echo "${PPID} NTFS Quick on Read Only" >> /tmp/automount.log
                fi
            else
                echo "{PPID} Quick Checked"
            fi
        fi
        if [ "$fstype" == "hfsplus" ]; then
                chkhfs -f --safe /dev/$1
                result=$?
                    echo "${PPID} HFS Quick check Failed" >> /tmp/automount.log
                    chkhfs -f /dev/$1
                else
                    echo "${PPID} HFS Quick check Passed" >> /tmp/automount.log
                fi
            fi
        fi
    fi
check_HFS_dir_permission()
    isHFSplus=`blkid /dev/$1 | sed -n 's/.*TYPE="\([^"]*\)".*/\1/p'`
    # echo "isHFSplus ${isHFSplus}" >> /tmp/automount.log
    if [ "$isHFSplus" == "hfsplus" ]; then
        perm=`ls -ld /shares/Storage | awk '{ print $1 }' | sed 's/-//g'`
        if [ "${#perm}" -ne 10 ]; then
            chmod 777 /shares/Storage -R
            echo "change permission for /share/Storage" >> /tmp/automount.log
        fi
    fi
my_mount()
    echo "${PPID} ${dev} USB:${USBdev} HD:${HDDdev}" >> /tmp/automount.log
    mount_type=Internal
    add_video_format
    mount_point=sdb1
    mkdir -p "${destdir}/${mount_point}" || exit 1
    isFAT32=`blkid /dev/$1 | grep vfat | wc -l`
    if [ ${isFAT32} -eq 1 ]; then
        fstype=vfat
        isDirty=`fsck.fat -n "/dev/$1" | grep "Dirty bit is set"  | wc -l`
        check_pmxcache
        if [ $isCacheEnabled -eq 1 ]; then
            isMounted=`mount | grep -c "/media/sdb1 type ${CacheModName}"`
            if [ $isMounted -eq 0 ]; then
                if ! mount -t ${CacheModName} -o ${CacheModName}=pmxfs "/dev/$1" "${destdir}/$mount_point"; then
                    rmdir "${destdir}/$mount_point"
                    /sbin/StorageAlert.sh $mount_point $devstr $dev &
                    exit 1
                fi
            fi
        else
            if ! mount -t auto -o async -o utf8=1 "/dev/$1" "${destdir}/${mount_point}"; then
                rmdir "${destdir}/${mount_point}"
                /sbin/StorageAlert.sh ${mount_point} ${devstr} ${dev} &
                exit 1
            fi
        fi
    else
        fstype=ufsd
        isDirty=`blkid /dev/$1 | grep DIRTY | wc -l`
        echo "${PPID} Mount on $1" >> /tmp/automount.log
        check_pmxcache
                isDiscard=`cat /etc/TRIM_Enable`
                if [ ${isDiscard} = "" ];then
                    isDiscard=0
                fi
                if [ ${isDiscard} -eq 1 ]; then
                    mountOpt="async,force,fmask=0000,dmask=0000,discard"
                else
                    mountOpt="async,force,fmask=0000,dmask=0000"
                fi
                if ! mount -t ${CacheModName} -o "${CacheModName}=pmxfs,${mountOpt}" "/dev/$1" "${destdir}/${mount_point}"; then
                    exit 1
                fi
            else
                echo "${PPID} Already mount on $1" >> /tmp/automount.log
                exit 1
            fi
        else
            if ! mount -t ufsd -o "${mountOpt}" "/dev/$1" "${destdir}/${mount_point}"; then
                # failed to mount, clean up mountpoint
                rmdir "${destdir}/${mount_point}" 2>&1 > /dev/null
                echo "${PPID} Already mount on $1 or mount fail" >> /tmp/automount.log
                exit 1
            fi
        fi
    fi
    mounted=`mount | grep "$1 " | wc -l`
    if [ ${mounted} -eq 0 ]; then
        exit 1
    fi
    if [ ${isDirty} -ne 0 ]; then
        /usr/local/sbin/sendAlert.sh 0007 &
    fi
    if [ ${ishddrive} -eq 1 ]; then
        isDataV=`mount | grep "DataVolume" | wc -l`
        if [ ${isDataV} -eq 0 ]; then
            mount /media/sdb1 /DataVolume
            mount --bind /media/sdb1 /shares/Storage
            check_HFS_dir_permission $1
            if [ ! -f /tmp/HDSerial ]; then
                HDSerial_temp=`hdparm -I \`cat /tmp/HDDDevNode\` | sed -n -e 's/.*Serial Number:\(.*\)/\1/p' | sed -e 's/^[ \t]*//' | awk '{gsub("WD-","",$0); print $0}'`
                HDSerial=${HDSerial_temp// /}
                echo "${HDSerial}" > /tmp/HDSerial
            else
                HDSerial=`cat /tmp/HDSerial`
            fi
            result=`sqlite3 /usr/local/nas/orion/orion.db 'select * from Volumes' | grep "${HDSerial}"_1  | wc -l`
            if [ ${result} == "0" ]; then
                /usr/local/sbin/volume_mount.sh mount "${HDSerial}"_1 "" "/dev/$1" ${fstype}
            fi
        fi
        #echo "/dev/${HDDdev}" > /tmp/HDDDevNode
        echo "/dev/$1" > /tmp/MountedDevNode
        rm /var/tmp
        ln -s /CacheVolume /var/tmp
        #factory_conf="/etc/nas/config/factory.conf"
        #if [ ! -f $factory_conf ] ||  [ `grep FACTORY_MODE $factory_conf | wc -l` != "1" ] || [ `grep FACTORY_MODE $factory_conf | awk -F= '{print $2}'` != "1" ]; then
        if [ ! -f /media/sdb1/.wdcache ]; then
        fi
        if [ ! -f /media/sdb1/.wdcache/coredump ]; then
            mkdir -p /media/sdb1/.wdcache/coredump
        fi
        if [ ! -L /var/lib/systemd/coredump ]; then
            mv /var/lib/systemd/coredump/* /media/sdb1/.wdcache/coredump/
            rmdir /var/lib/systemd/coredump
            ln -sf /media/sdb1/.wdcache/coredump /var/lib/systemd/coredump
        fi
    fi
#Video format for FUSE(file cache)
add_video_format()
    if [ -f /tmp/videoformat ]; then
        rm /tmp/videoformat
    fi
    if [ ! -f /usr/local/wdmcserver/bin/mime_types.txt ]; then
        echo .mp4 >> /tmp/videoformat
        echo .avi >> /tmp/videoformat
        echo .wmv >> /tmp/videoformat
        echo .rm >> /tmp/videoformat
        echo .rmvb >> /tmp/videoformat
        echo .mov >> /tmp/videoformat
        echo .dat >> /tmp/videoformat
        echo .m1v >> /tmp/videoformat
        echo .mp3 >> /tmp/videoformat
        echo .wma >> /tmp/videoformat
        echo .mkv >> /tmp/videoformat
   else
        cat /usr/local/wdmcserver/bin/mime_types.txt | grep video/  > /tmp/mime_types.tmp1
        sed '/#/d' /tmp/mime_types.tmp1 > /tmp/mime_types.tmp2
        awk '{ {if($2!="")print "."$2} {if($3!="")print "."$3} {if($4!="")print "."$4}  {if($5!="")print "."$5} }' /tmp/mime_types.tmp2  > /tmp/videoformat1
        cat /tmp/videoformat1 | awk -F'\t' '{print $1}' | tr '\n' ', ' > /tmp/videoformat
        rm /tmp/videoformat1
        rm /tmp/mime_types.tmp1
        rm /tmp/mime_types.tmp2
   fi
action_add_internal_hdd()
    isHdrType=`blkid /dev/$1 | grep "PTTYPE=" | wc -l`
    if [ ${isHdrType} -ne 0 ]; then
        isKnownType=`blkid /dev/$1 | grep " TYPE=" | wc -l`
        if [ ${isKnownType} -eq 0 ]; then
            echo "$1 is Header Type!!"
            return
        fi
    fi
        echo "$1 Type Unknown!!"
        return
    fi
    isHDDMount=`grep /dev/$1 /proc/mounts | wc -l`
    if [ ${isHDDMount} -eq 1 ]; then
       echo "HDD already mounted"
    else
      echo "Try to Mounte HDD"
      isGPT=`blkid /dev/$1 | grep -i "efi system" | wc -l`
      if [ ${isGPT} -eq 1 ]; then
           echo "***GPT found, ignore $1***"
           return
      fi
        #my_check $1
        my_mount $1
    fi
#echo "${PPID} ${ACTION} ${DEVNAME} $1 $2 $3 $4" >> /tmp/automount.log
#Find all sda [Internal HDD]
echo "/dev/sda" > /tmp/HDDDevNode
ALLSDA=`cd /dev && ls -1 sda*`
umask 0000
for SDA in $ALLSDA ; do
    if [ $SDA != "" ]; then
        echo "Find $SDA"
        action_add_internal_hdd $SDA
    fi
done
I’ve confirmed that files work fine when they are located on a mounted ext4 formatted usb drive.
Attempting to format the main drive to ext4 causes the mount script to fail however and no drives end up being mounted.
Judging by the mount script it doesn’t look like they intended for ext4 formatted drives to mount, which is unusual since they explicitly state support for said file system.
Caching could also be part of the issue.
Just need someone more versed in bash to chime in and help rewrite the mount script to support ext4 and/or disable caching.
Edit:
Commenting out the line below disables the cache and fixes the issue.
If you attempt the fix I’d avoid optimising files and possibly turning on the cache and rebooting before updating Plex.
I haven’t tested if it affects SD/USB importing or the twonky server.
Chime in if you have a fix that doesn’t require disabling the cache.
YMMV. Do at your own risk.
/sbin/intlmount.sh
For reference the cache directories contain these files:
.USB/
.wdcache/.twonkymedia/...
.wdcache/coredump/...
.wdcache/wd-alert
.wdcache/plexmediaserver-1.24.3.5033-757abe6b4.bin
.wdcache/plexmediaserver.img
.wdcache/update.log
.wdmc/Storage/...
.wdmc/wdmc.db
.wdmc/wdmc.db-shm
.wdmc/wdmc.db-wal
