it keep saying failed to download subtitle, to all my movies, and i dont know why
my plax is installed on a nas server
Can you grab the server logs and upload the zip file here?
I suspect the error is because PlexMediaServer can’t write (save) the subtitle files.
Can you help me understand this?
Nov 11, 2022 18:35:03.162 [0xee4f0d90] DEBUG - [Req#4db4] [Now] Device is Chrome (Chrome).
Nov 11, 2022 18:35:03.162 [0xee4f0d90] DEBUG - [Req#4db4] [Now] Profile is Web
Nov 11, 2022 18:35:03.162 [0xee4f0d90] DEBUG - [Req#4db4] [Now] Updated play state for /library/metadata/20925.
Nov 11, 2022 18:35:03.163 [0xee4f0d90] DEBUG - [Req#4db4] Statistics: (31f0f5xlv8yyc70yqgow183n) Reporting active playback in state 0 of type 1 (scrobble: 0) for account 1
Nov 11, 2022 18:35:03.170 [0xf301ad90] DEBUG - Completed: [192.168.0.128:58467] 200 GET /:/timeline?ratingKey=20925&key=%2Flibrary%2Fmetadata%2F20925&playbackTime=19042&playQueueItemID=673&state=playing&hasMDE=1&context=library%3Acontent.library&row=92&col=7&time=226000&duration=11209000 (8 live) TLS GZIP 16ms 819 bytes (pipelined: 6)
Nov 11, 2022 18:35:06.857 [0xf2e17d90] DEBUG - Failed to stream media, client probably disconnected after 8519680 bytes: 32 - Broken pipe
Nov 11, 2022 18:35:06.857 [0xf2e17d90] DEBUG - Completed after connection close: [192.168.0.128:58465] 206 GET /library/parts/30517/1648816294/file.mp4?Accept-Language=da (7 live) TLS 14252ms 8519680 bytes (pipelined: 2) (range: bytes=39944192-2187427838)
Nov 11, 2022 18:35:06.861 [0xee2edd90] DEBUG - Request: [192.168.0.128:58467 (Subnet)] GET /library/parts/30517/1648816294/file.mp4?Accept-Language=da (5 live) #4db7 TLS Signed-in Token (andyidel) (Chrome) (range: bytes=46268416-2193752062)
Nov 11, 2022 18:35:06.868 [0xee2edd90] DEBUG - Content-Length of /volume5/Film/Film/Titanic.1997.HDTV.1080p.x264.YIFY.mp4 is 2147483647 (of total: 2242234377).
Nov 11, 2022 18:35:06.939 [0xee4f0d90] DEBUG - Request: [192.168.0.128:58468 (Subnet)] OPTIONS /subtitles/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F20925&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=1&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=se5exlk8ljyrsg1v7gvme136&subtitles=sidecar©ts=1&Accept-Language=da&offset=259 (5 live) #2d2c TLS GZIP Signed-in Token ()
Nov 11, 2022 18:35:06.939 [0xf301ad90] DEBUG - Completed: [192.168.0.128:58468] 200 OPTIONS /subtitles/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F20925&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=1&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=se5exlk8ljyrsg1v7gvme136&subtitles=sidecar©ts=1&Accept-Language=da&offset=259 (5 live) TLS GZIP 0ms 376 bytes (pipelined: 2)
Nov 11, 2022 18:35:06.942 [0xeecfcd90] DEBUG - Request: [192.168.0.128:58468 (Subnet)] GET /subtitles/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F20925&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=1&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=se5exlk8ljyrsg1v7gvme136&subtitles=sidecar©ts=1&Accept-Language=da&offset=259 (5 live) #4dbb TLS GZIP Signed-in Token (andyidel) (Chrome)
Nov 11, 2022 18:35:06.942 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Found session GUID of se5exlk8ljyrsg1v7gvme136 in session start.
Nov 11, 2022 18:35:06.943 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: append-transcode-target-codec(type=videoProfile&context=streaming&audioCodec=aac&protocol=http)
Nov 11, 2022 18:35:06.943 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] TranscodeUniversalRequest: using augmented profile Web
Nov 11, 2022 18:35:06.943 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Downloading document http://127.0.0.1:32400/library/metadata/20925?checkFiles=1&includeBandwidths=1&offset=259&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=wlnds4deu4gdjpvxhqtwbleq
Nov 11, 2022 18:35:06.980 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode/Req#4dbc] It took 50.000000 ms to retrieve 146 items.
Nov 11, 2022 18:35:07.026 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode/Req#4dbc] It took 80.000000 ms to retrieve 146 items.
Nov 11, 2022 18:35:07.033 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode/Req#4dbc] We're going to try to auto-select an audio stream for account 1.
Nov 11, 2022 18:35:07.033 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode/Req#4dbc] Selecting best audio stream for part ID 30517 (autoselect: 1 language: en)
Nov 11, 2022 18:35:07.034 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode/Req#4dbc] Audio Stream: 69892, Subtitle Stream: 179574
Nov 11, 2022 18:35:07.050 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Destroying existing session, reference count = 4
Nov 11, 2022 18:35:07.051 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Cleaning directory for session se5exlk8ljyrsg1v7gvme136 ()
Nov 11, 2022 18:35:07.051 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Killing job.
Nov 11, 2022 18:35:07.051 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Signalling job ID 6753 with 9
Nov 11, 2022 18:35:07.051 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Job was already killed, not killing again.
Nov 11, 2022 18:35:07.051 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Stopping transcode session se5exlk8ljyrsg1v7gvme136
Nov 11, 2022 18:35:07.052 [0xead23d90] DEBUG - [Req#4dbb/Transcode] Cleaning directory for session se5exlk8ljyrsg1v7gvme136 (/volume1/Plex/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-se5exlk8ljyrsg1v7gvme136-19dcf4d1-f16d-4166-be92-a7cb10310609)
Nov 11, 2022 18:35:07.164 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Starting a transcode session se5exlk8ljyrsg1v7gvme136 at offset -1.0 (state=3)
Nov 11, 2022 18:35:07.164 [0xee8f6d90] DEBUG - [Req#4dbb/Transcode] Job was already killed, not killing again.
Nov 11, 2022 18:35:07.164 [0xee8f6d90] DEBUG - [Req#4dbb/Transcode] Whacked session se5exlk8ljyrsg1v7gvme136, 1 remaining.
Nov 11, 2022 18:35:07.166 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode/HCl#49] HTTP requesting GET http://127.0.0.1:32400/library/streams/179574?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Nov 11, 2022 18:35:07.167 [0xeeeffd90] DEBUG - Request: [127.0.0.1:33696 (Loopback)] GET /library/streams/179574 (5 live) #2d2f GZIP Signed-in Token (andyidel) (Synology)
Nov 11, 2022 18:35:07.236 [0xf301ad90] DEBUG - Completed: [127.0.0.1:33696] 200 GET /library/streams/179574 (5 live) GZIP 68ms 43466 bytes (pipelined: 4)
Nov 11, 2022 18:35:07.238 [0xf073bd90] DEBUG - [HttpClient/HCl#49] HTTP/1.1 (0.1s) 200 response from GET http://127.0.0.1:32400/library/streams/179574?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (reused)
Nov 11, 2022 18:35:07.240 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Detected character set of UTF-8.
Nov 11, 2022 18:35:07.241 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] Downloaded stream from [http://127.0.0.1:32400/library/streams/179574?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx] (codec: srt) to temporary file [/volume1/Plex/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-se5exlk8ljyrsg1v7gvme136-9914d38c-f08d-43c9-8938-9164840da868/temp-0.srt]
Nov 11, 2022 18:35:07.242 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode] TPU: hardware transcoding: final decoder: , final encoder:
Nov 11, 2022 18:35:07.244 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/c4efa15-4387-linux-x86/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxx4821-9754-371a24cb1078 "/volume1/@appstore/Plex Media Server/Plex Transcoder" -ss 259 -analyzeduration 20000000 -probesize 20000000 -i "/volume1/Plex/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-se5exlk8ljyrsg1v7gvme136-9914d38c-f08d-43c9-8938-9164840da868/temp-0.srt" -map 0:s:0 -metadata:s:0 language=dan -codec:0 ass -strict_ts:0 0 -f segment -segment_format ass -segment_time 1 -segment_header_filename header -segment_start_number 0 -segment_list "http://127.0.0.1:32400/video/:/transcode/session/se5exlk8ljyrsg1v7gvme136/9914d38c-f08d-43c9-8938-9164840da868/manifest?X-Plex-Http-Pipeline=infinite" -segment_list_type csv -segment_list_unfinished 1 -segment_list_size 5 -segment_list_separate_stream_times 1 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 "chunk-%05d" -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/se5exlk8ljyrsg1v7gvme136/9914d38c-f08d-43c9-8938-9164840da868/progress
Nov 11, 2022 18:35:07.245 [0xeecfcd90] DEBUG - [Req#4dbb/Transcode/JobRunner] Jobs: Starting child process with pid 6764
Nov 11, 2022 18:35:07.262 [0xf0327d90] DEBUG - Request: [127.0.0.1:40227 (Loopback)] PUT /video/:/transcode/session/se5exlk8ljyrsg1v7gvme136/9914d38c-f08d-43c9-8938-9164840da868/progress?status=startup (6 live) #4d96 Signed-in Token (andyidel) (range: bytes=0-)
it works if i upload from thirdpart (subscene)
but plex wont download any
who are you attempting to download from (in PMS)?
There were no download errors nor any permission errors (what I expected) of either kind.
Go to settings –> account
And look here
If you have it selected the way I do you will rarely get any downloads. Opensubtitles has a pretty poor selection of foreign language only/forced subtitles
Change that selection and try again… “only show SDH subtitles” could also be a problem
May I have your ZIP logs now please with this fresh download error in it?
Any update on this #ChuckPa?
it stil says the same “Failed to download subtitle.”
