My Synology PlexMediaServer folder takes up a lot of storage
Hello,
My Synology PlexMediaServer folder currently holds 10.26 GB of data. I find that rather much considering I do not have that much music or movies (no more than 25 GB of music an about 15 movies that indeed are large).
I see that the largest folders within PlexMediaServer is
Metadata 1,45 GB
Cache 6,21 GB
Media 1,78 GB
Now I tried to delete the Preview Thumbnails as suggested in this thread:
But it did nothing at all.
Can I safely delete the Cache folder or the contents within?
I tried to dele this from the iOS app(reset cache), but nothing happened there either.
Is there something else I should consider?
Thank you trumpy81!
Following your suggestion I was able to free up 6,2 GB out of the 10!
