My tv does not show 4 digit code
My tv does not show 4 digit code. Tv samsung
You didn’t specify vendor nor model of your TV, but this is sadly a typical example for a TV, where the Vendor stopped upgrading the firmware, so new security protocols and chipers are supported.
If there’s no firmware updates avail from the TV vendor, then there’s sadly nothing that can be done about this, and you need to look for an external player for your TV, like a Shield, Chromecast, Apple-TV or siml.
Ref: Plex support is ending 2020-09-30 on older smart TV devices
Thank you for answer. Yes it is old model ue32eh5307 and no new firmware
Making it Samsung, running Orca client, so sadly, nothing we can do to help.
You need to look into alternative clients
