Hi there,
i got the weirdest problem suddenly. I had my internet hardware replaced by my local internet provider (you know, pay more, get faster internet blabla) and now suddenly i cannot connect it anymore to my pc.
I removed and downloaded the TV app several times now, like, a clean install.
when i start the app it shows this:
As you can see, in the past, and Normally, you`d get a 4 digit code that you than enter in provided link and voila connection is made. It just blatantly refuses to show me this code. I checked if it was the internet connection to my tv first but it states that the connection is fine. I mean, why wouldn’t it? I could not have downloaded plex on my tv in the first place if the internet to itself was faulty.
Some specs:
My TV is a Samsung smart TV UE40EH5300
My PC is a custom build one running with W7. I could give specific specs all you need, if needed, but i suspect the problem lies with the TV end since my library is still functional etc.
If you need anymore information, don’t hestitate to ask me!
Thanks in advance! /tela
