I’ve seen several discussions about naming TV episodes that are in two parts, and I’ve done that successfully, however I have kind of the opposite problem. With some DVD seasons, several two part episodes that aired on television are merged together as one episode. Not sure how to name these, as if I name them ShowName-S01E01-E02 - Show Title, it just puts the episode on there twice. Should I just name it, for example, ShowName-S01E01, and then skip E02 and then just use E03 after that?
- you need a space: ShowName - S01E01-E02 - Episode Name.xxx
or - you need to investigate your TV Show File Naming and Structuring in General
or - if you’re using MP4/M4V files with embedded and bogus Title Fields throwing Plex into a tailspin - Move Local Media Assets to the bottom of every agent list you can find at ‘Plexweb/Settings/Server/Agents/Shows and Movies’.
but - name the first one, skip one, then name the next one is far better because Plex sucks at double episodes anyway.
