"NAS" est actuellement indisponible
Server Version#: 1.25.6.5577-7000
Player Version#: 4.75.0
Hello,
Following a migration to NAS Synology DS920+ and the replacement of my hard drives, I cannot reconnect my server and recover my library.
The message on Plex is:
“my server name” is currently unavailable
During the migration phase, Plex stopped working and I had to uninstall it (keeping the data) and reinstall it manually because it no longer appeared in the package sources.
Sorry for the google translate and thanks for your help.
Anthony
Try to follow the @ChuckPa guide to migrate your PMS to another Synology, I used it recently and works like a charm. Thanks @ChuckPa :smiley:
Continuo en español que será más fácil…
Básicamente es un tema de permisos con el usuario de Plex, al copiar los datos has perdido el propietario del archivo, si sigues la guia de migración no tendrás ningún problema, yo hice una migración hace poco y funcionó genial.
I have already migrated.
Currently, the last disk is under repair.
On File Station, I see:
Plex folder with inside:
  • Library folder
  • tmp_transcoding folder
as well as a PlexMediaServer folder with:
  • AppData folder
