NAS Synology not sleep
I have problems with the Hibernation functionality of Synology.
When the Plex Connect is up, my Synology not hibernate, if I stop the Application Plex Connect, then yes.
I was reviewing the file PlexConnect.log and I can read that every 2 or  3 minutes a DNSServer line is writed, like next:
21:14:47 DNSServer: ***forward request
21:14:47 DNSServer: -> DNS response from higher level
21:16:14 DNSServer: DNS request received!
21:16:14 DNSServer: Source: ('XXX.XXX.XXX.XXX', 52865)
21:16:14 DNSServer: Domain: 43-courier.push.apple.com
21:16:14 DNSServer: ***forward request
21:16:14 DNSServer: -> DNS response from higher level
21:16:18 DNSServer: DNS request received!
21:16:18 DNSServer: Source: ('XXX.XXX.XXX.XXX', 50296)
21:16:18 DNSServer: Domain: itunes.apple.com
21:16:18 DNSServer: ***forward request
21:16:18 DNSServer: -> DNS response from higher level
21:17:41 DNSServer: DNS request received!
21:17:41 DNSServer: Source: ('XXX.XXX.XXX.XXX', 53533)
21:17:41 DNSServer: Domain: 31-courier.push.apple.com
21:17:41 DNSServer: ***forward request
21:17:41 DNSServer: -> DNS response from higher level
21:17:45 DNSServer: DNS request received!
21:17:45 DNSServer: Source: ('XXX.XXX.XXX.XXX', 54943)
The IP XXX.XXX.XXX.XXX, is my ATV3 device, and my ATV3 is shutdown!!!
Someone has the same problem?
How can I make Plex Connect sleep?
How can I stop or slow the log level? I tried with loglevel = Low, but I have the same problem, my Synology device not hibernate.
thank you very much for your help
