need help, I read everything but something is a miss so here goes
ATV 2 firmware 5.3(6105)
192.168.2.64
dell inspiron 560  win 7
192.168.2.64
Dell inspiron 560 win 7
plex media server 0.9.8.10
192.168.2.64
12/10/13 10:25am
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 192.168.178.10
enable_plexgdm = True
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
Problem is when I click trailers it says it's unavailable
plex connect log
10:25:39 PlexConnect: started: 10:25:39
10:25:39 PlexConnect: IP_self: 192.168.2.64
10:25:40 DNSServer: started: 10:25:40
10:25:40 DNSServer: ***
10:25:40 DNSServer: DNSServer: Serving DNS on 192.168.2.64 port 53.
10:25:40 WebServer: started: 10:25:40
10:25:40 WebServer: ***
10:25:40 WebServer: WebServer: Serving HTTP on 192.168.2.64 port 80.
10:25:42 WebServer: ***
10:25:42 WebServer: WebServer: Serving HTTPS on 192.168.2.64 port 443.
I hope I listed everything required please let me know if I missed something.  I followed all the instructions from github
Did you generate and install the SSL certs to the PlexConnect folder and the ATV?
yes I created the ssl certs, I moved 2 of them to the cert folder in the plex master folder then,
I used the iphone configuration utility to install the cert onto the atv, after selecting install, it did change to remove which is the only confirmation that it should have worked, BUT, the instructions state if that worked you shouldn't have to create a 2nd profile on the ATV, in my case, I did have to do that.
So I went to the ATV and created the 2nd profile by entering the http: my ip address above/trailer.cer (typing this from memory can't remember if I typed trailer or trailers) but none the less I followed those directions.
How to do I figure out where I went wrong?
You should have only one trailers related profile on the aTV. Either via iphone configuration utility or directly using PlexConnect WebServer.
Did you set your DNS Address on aTV to your PlexConnect host? I am missing DNS related lines in your log.
After installing the cert via usb and the iphone utility it did NOT create a trailers profile on the ATV2 which is why I manually created one.   My IP address is the same for everything, my Plex server, my computer, my DNS setting on the ATV2 are all the same IP address which is what I got by following the directions, let me know if that's wrong.
Did you set inbound rules for TCP and UDP for Python.exe?
NO, I did nothing with python.exe ecxept to click it, which is all the instructions said to do, I do not know how to set inbound rules for tcp and udp.....this process is unfortunately a little over my head but if you would be willing to explain what you're saying I'll most likely be able to pick it up
