Trailers is unavailable
Just bought myself a new hard drive and struggling to get plex connect working. On my old hard drive it worked like a charm.
Your ATV model: Apple tv 3 (7.0.1)
The DNS server set on the ATV:  192.168.1.3
The local IP address of the device that PlexConnect is installed on: 192.168.1.3
The device and operating system (including version number) that PlexConnect is installed on: Windows 8.1
The device and operating system (including version number) that the Plex media server (PMS) is installed on: Windows 8.1
The Plex media server (PMS) version number you are running (do not put ‘latest'): 0.9.11.7
The local IP address of the device that the Plex media server is installed on: 192.168.1.3
The PlexConnect version number: Downloaded today
The contents of your 'Settings.cfg' file:
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
allow_gzip_atv = False
allow_gzip_pmslocal = False
allow_gzip_pmsremote = True
loglevel = Normal
logpath = .
A detailed description of the issue (the clearer you can make this the better): When i click on trailers it says “trailers is unavailable. Try again later
Log File:
20:47:19 PlexConnect: started: 20:47:19
20:47:19 PlexConnect: Version: 0.5-dev
20:47:19 PlexConnect: Python: 2.7.9 (default, Dec 10 2014, 12:24:55) [MSC v.1500 32 bit (Intel)]
20:47:19 PlexConnect: Host OS: win32
20:47:19 PlexConnect: PILBackgrounds: Is PIL installed? False
20:47:19 Settings: getsetting enable_plexconnect_autodetect=True
20:47:19 PlexConnect: IP_self: 192.168.1.3
20:47:19 Settings: getsetting hosttointercept=trailers.apple.com
20:47:19 Settings: getsetting enable_dnsserver=True
20:47:19 DNSServer: started: 20:47:19
20:47:19 Settings: getsetting port_dnsserver=53
20:47:19 Settings: getsetting ip_dnsmaster=8.8.8.8
20:47:19 Settings: getsetting prevent_atv_update=True
20:47:19 DNSServer: ***
20:47:19 DNSServer: DNSServer: Serving DNS on 192.168.1.3 port 53.
20:47:19 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.3
20:47:19 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
20:47:19 DNSServer: forward other to higher level DNS: 8.8.8.8
20:47:19 WebServer: started: 20:47:19
20:47:19 Settings: getsetting port_webserver=80
20:47:19 WebServer: ***
20:47:19 WebServer: WebServer: Serving HTTP on 192.168.1.3 port 80.
20:47:19 Settings: getsetting enable_webserver_ssl=True
20:47:19 Settings: getsetting port_ssl=443
20:47:19 Settings: getsetting certfile=./assets/certificates/trailers.pem
20:47:19 WebServer: WebServer: Serving HTTPS on 192.168.1.3 port 443.
20:47:35 DNSServer: DNS request received!
20:47:35 DNSServer: Source: ('192.168.1.82', 57837)
20:47:35 DNSServer: Domain: trailers.apple.com
20:47:35 DNSServer: ***intercept request
20:47:35 DNSServer: -> DNS response: 192.168.1.3
20:47:54 PlexConnect: Shutting down.
20:47:54 WebServer: Shutting down (HTTP).
20:47:54 WebServer: Shutting down (HTTPS).
20:47:55 DNSServer: Shutting down.
20:47:55 PlexConnect: shutdown
Have you rebooted your aTV after loading your certs? Did you follow this guide:
Wiki - Install Guide
Any antivirus, firewall, virtual machine software?
Do i need to add new certs? The apple tv was already set up.
I have restarted the apple tv.
I am using the same static ip address which i used before. Shall i change this to something else or not?
I would generate/load new certs on the host and aTV then reboot the aTV to rule out the certs as being the issue.
Did you create new certs on your PlexConnect host?
If so... yes, you need the same certs on aTV.
You sir are a legend. thank you it is working now i will do the same on my other apple tv
