need help installing plex server after opensuse install
i am running with an opensuse leap 42.2 system.
i already have a plex account and had a plex server.
after installing opensuse, i no longer have a plex server.
now i am unable to install the plex server.
i receive an error:
Error: INVALID:plexmediaserver-1.8.1.4139-c789b3fbb.x86_64 (file-2f358519): Signature verification failed [4-Signatures public key is not available]
Header V4 RSA/SHA1 Signature, key ID 3adca79d: NOKEY
Header SHA1 digest: OK (adb763dcfdfd432fee0a0e6d66af04eb46bacff0)
MD5 digest: OK (fc9388a89d2cc4f6da4947c9b824b5e6)
any suggestions would be helpfull.
thanks
Opensuse isn’t one of Plex’s supported Linux distributions.
If OpenSuse is like Ubuntu, you can import the Plex signing key.
If interest to you is the signing key.
https://support.plex.tv/hc/en-us/articles/235974187-Enable-repository-updating-for-supported-Linux-server-distributions
It may help if you mention what you used to install pms on leap.
Unable to reproduce error
rpm -Uvh plexmediaserver-1.8.1.4139-c789b3fbb.x86_64.rpm
warning: plexmediaserver-1.8.1.4139-c789b3fbb.x86_64.rpm: Header V4 RSA/SHA1 Signature, key ID 3adca79d: NOKEY
Preparing… ################################# [100%]
Updating / installing…
1:plexmediaserver-1.8.1.4139-c789b3################################# [100%]
Synchronizing state of plexmediaserver.service with SysV init with /usr/lib/systemd/systemd-sysv-install…
Executing /usr/lib/systemd/systemd-sysv-install enable plexmediaserver
Created symlink from /etc/systemd/system/multi-user.target.wants/plexmediaserver.service to /lib/systemd/system/plexmediaserver.service.
Or use:
zypper in plexmediaserver-1.8.1.4139-c789b3fbb.x86_64.rpm
Works for me on 42.3.
The only thing I have issues with is that the restart of the service throws an error during the process.
I’m also running OpenSuSE Leap, I’ve tried both ways shown here and am receiving the following:
($)─> sudo zypper in plexmediaserver-1.15.4.994-107756f7e.x86_64.rpm
[sudo] password for root:
Error building the cache:
[downloads|hd:///home/avp/downloads?device=/dev/disk/by-id/wwn-0x5000000000000000-part1&filesystem=auto] Valid metadata not found at specified URL
Warning: Skipping repository ‘downloads’ because of the above error.
Some of the repositories have not been refreshed because of an error.
Loading repository data…
Reading installed packages…
Resolving package dependencies…
The following NEW package is going to be installed:
plexmediaserver
1 new package to install.
Overall download size: 103.5 MiB. Already cached: 0 B. After the operation, additional 224.1 MiB will be used.
Continue? [y/n/…? shows all options] (y):
Retrieving package plexmediaserver-1.15.4.994-107756f7e.x86_64 (1/1), 103.5 MiB (224.1 MiB unpacked)
plexmediaserver-1.15.4.994-107756f7e.x86_64.rpm:
Looking for gpg key ID 3ADCA79D in cache /var/cache/zypp/pubkeys.
Repository Plain RPM files cache does not define additional ‘gpgkey=’ URLs.
plexmediaserver-1.15.4.994-107756f7e.x86_64 (Plain RPM files cache): Signature verification failed [4-Signatures public key is not available]
Abort, retry, ignore? [a/r/i] (a):
From YaST2 - Add Software
An error occurred during repository initialization. [downloads|hd:///home/avp/downloads?device=/dev/disk/by-id/wwn-0x5000000000000000-part1&filesystem=auto] Valid metadata not found at specified URL History: - [downloads|hd:///home/avp/downloads?device=/dev/disk/by-id/wwn-0x5000000000000000-part1&filesystem=auto] Repository type can’t be determined.
Error: INVALID:plexmediaserver-1.15.4.994-107756f7e.x86_64 (file-e10e7eab): Signature verification failed [4-Signatures public key is not available]
MD5 digest: OK
Any thoughts, oh wise ones???
Thanks in advance.
  1. The key info is here:
    https://support.plex.tv/articles/235974187-enable-repository-updating-for-supported-linux-server-distributions/
  2. It’s probably best to download and do a local install the first time.
