Hello,
the series " Money Heist" has a differed order at Netflix than the aired order.
There is a drop down in advanced options which allows to switch between DVD, absolute and aired order… is there a way to add the Netflix order?
Sincerely,
Hello,
Sincerely,
interestingly, TheTVDb.com actually offers a “Netflix order” as an alternate order… however it looks quite unorganized (not necessarily a problem with the netflix order… the entire show doesn’t seem to be in a good shape on TheTVDb w/ 23 or 30 episodes not assigned to a season at all nor much metadata of any kind)
https://www.thetvdb.com/series/la-casa-de-papel/allseasons/alternate
Yes,
the Netflix order is much better… every episode is assigned and exactly like on Netflix…
The “Aired order” is a mess
Not on TheTVDb.com… there’s 23 episodes listed without an assignment to a season.
Ah sorry,
I focused on the season 1 to 3… the season 4 starts at the next month
So, who dreams up this ‘Netflix Order’?
Netflix?
I seem to remember a similar difficulty with FireFly wherein Network Executives thought they knew better than the guy that wrote it - changed it all around - got it cancelled in a season - and moved on to the next self inflicted disaster.
I also seem to recall the DVD Order at TMDB is the only (practical) way to get to see the ‘intended’ order of FireFly. That bit is working fine at my house.
I think I’ll stick with Aired Order - if that coincides with the order intended by it’s creator. If Netflix has an order they like better we all may be in trouble.
You may want to add your vote to that feature request:
