I’m having same issue, I posted before I had seen this Post.
Bump.
Looks like the link is correctly populating now.
New update available (4707) and again this is only a tgz file when downloaded from within the server. Why has this happened again? Can it be fixed rather than having to trawl through the downloads page to find the correct file?
That is version 1.23.3. This has to do with how the original files are being named and found by the downloads page. Starting with 1.23.4, which is currently in beta, things should be correct. For now, if you need to download the file, you’ll have to use the beta or manually edit the URL like mentioned above.
And… it’s broken again.
try:
https://downloads.plex.tv/plex-media-server-new/1.23.3.4707-ebb5fe9f3/netgear/plexmediaserver-annapurna_1.23.3.4707-ebb5fe9f3_armel.deb
@fricklas This looks like an old version. Where was the link from? Did that come from inside the NAS app or off the website?
@fricklas As mentioned, it will be fixed with 1.23.4.
Thank you for the correct link fricklas.
its happened again, any direct link out there?
The correct link is shown on the Download page. Can you double check.
