New downloads feature does not seem to work properly for me
I tried to wait until an episode completed and it looks like it almost does and then it just errors saying error downloading, swipe to remove or tap. I clicked on that and the download restarted. Now it’s waiting to download because I also initiated a movie download.
Deleted the movie download (a feedback here: long pressing to delete is not intuitive, should just be a regular tap on the downloading to bring up the delete download menu - just tapping does not currently do anything)
Steps:
  • Open series
  • Tap the down arrow download button
  • Choose 3 episodes ahead, delete after a week
Now waiting until the episode completes. I see the percentage logs in the server console.
Server got to 100%, but in Downloads the load circle still is at almost finished. Libraries says no downloaded content. When I actually try to play the item, it errors as there was nothing downloaded. In Items, it has failed like before. Then restarts again. This keeps looping like that and never actually downloading anything successfully.
This happens with movie downloads as well.
Additionally, I do not see the Download menu item in the 3-dot menu as described here Download for Android Mobile | Plex Support for either movies or shows, only the down arrow button.
(Edit: Long pressing an item has Download in the context menu, as described in the support article.)
Plex for Android Logs.txt (1.3 MB)
added logs from the Help & Support > Share debugging data tool.
Thanks for the report! :plexheart:
Is there anything else I can do to test? It seems that the 2 movies I tried to sync finally completed, but TV shows refuse to sync. It just keeps starting over and never actually completing. Nothing ever shows up in the Libraries tab.
For the record - this is on a Samsung Galaxy S10+. Is it doing some app sleeping magic that interferes with sync?
Hmmm, I cleared app cache/data, uninstalled the app. After reinstalling, it seems to be a bit more stable. Looks more promising. I’ll keep you posted.
Ok, nope. It still just fails on some shows. Seems to be hit or miss.
Additional info: for movies, it transcodes (I have Video Quality set to 8 Mbps, 1080p HD), but seemingly not for shows. There may be a confounding variable here though which I am not aware of.
Thanks for the extra info. We’re still investigating this
Thanks for reporting the problem @silvertoaster, hopefully with some additional help from you we’ll get to the bottom of it.
So I see a lot of Sync activity (as in the old Sync feature, the one that we’re replacing with Downloads) in those logs, makes it hard to follow what’s going on (also the fact that you’re downloading multiple things).
Can you please:
  1. Delete your device from your “Authorized devices” list on plex.tv/web. This will ensure that any Sync items are deleted and the app doesn’t try to sync them again.
  2. Install the app from scratch, download one of the item that fails (and just that one), and share the logs once you’re reasonable sure that the operation has failed and no progress is being made.
Thanks in advance!
Done!
Followed the steps exactly.
Plex for Android Logs.txt (577.1 KB)
At the end of the download, it errors out with “There was an error downloading this file…” and when you tap it, the download restarts.
I also saw this error consistently throughout the download process:
I want to add, this seems to be happening (so far) with only that specific file/show. I tried another one, and it doesn’t error like this after downloading. The console errors still appear though.
I’m having very similar issues.
Downloads will just keep failing.
Please recreate and provide logs from the app and server.
I can reproduce this issue as well, except I can’t get movies to download either, everything fails with the same error you received.
