New error for files I've watched for years: invalid 'X-Plex-Device' header value
Server Version#: Version 1.41.6.9685
Player Version#: 2025.15.0 (966828394)
Error on player: Conversion failed. The transcoder exited due to an error
Logs:
LevelError
Thread
Message[Req#2e6939/ViewStateSync] [HttpHeader] invalid 'X-Plex-Device' header value (Raspberry Pi 5 Model B Rev 1.0�)
I would assume it has to do with that character at the end of the string, but am I able to fix that?
I get this error for some files but not all. In some cases I can change the transcoder value (eg. from original 10.1mbps to a preset eg. 1080p HD 8mbps) and it works, but this is not guaranteed to always work.
It’s a new challenge that’s started over the last week. It happens on files I’ve had in my library for some time and watched multiple times. It does not happen to all files.
I can play these problematic files via VLC universal plug and play on my PC with no issue.
Plex Media Server Logs_2025-05-15_09-22-29.zip (4.9 MB)
The header error is unrelated to the transcoder issue.
Best to supply the full server logs.
Updated original post
Thanks.
This appears to be the cause of the Transcoder error:
May 15, 2025 06:26:26.508 [140735362445536] ERROR - [Req#30feb2/Transcode/47112147-86ee-4f30-a36b-9786e3d28cdc/f87e696e-5f1e-4665-9782-5ad7c829e38f] [eac3_eae @ 0x7fffbc606380] EAE watchfolder is not writable: /tmp/pms-940dc235-7378-4f91-ac0f-3634d9609baa/EasyAudioEncoder/Convert to WAV (to 8ch or less)/47112147-86ee-4f30-a36b-9786e3d28cdc_700338-0-test.tmp
Make sure the /tmp path is writable and the Plex user has write access to it.
