New items not showing on Plexconnect - in Plex library
I am running PMS on my Mac. I have some new media which has been added to the library. It shows up on my Mac.
When I login to Plexconnect on my AppleTV3 the latest stuff isn't showing.
Any ideas?
Did you refresh your library? Do you have it set to detect new media automatically in PMS? What type of file container is it a .mp4,.mkv, etc?
It is showing in my library if I use the MediaManager.
It is only when I then go to PlexConnect on my AppleTV that these don't show.
So your previous media shows up? What file type is it that you added?
Which PlexConnect? The iBaa-latest?
Do you see those titles when browsing to http://127.0.0.1:32400/library//sections?
Yes, the latest version of PlexConnect
The link to library/sections doesn't work for me. (I did remove the ? at the end)
If I select MediaManager from the PMS dropdown on my iMac it goes to :
http://127.0.0.1:32400/web/index.html#!/dashboard
The shows in question show up there fine. I can also access them on my iOS Plex client as well.
For some reason these items are being added to my library but not showing in PlexConnect on the AppleTV
Yes, I can access all my previous media. It is only recently added stuff that isn't showing.
Delete everything from pms. Delete pms, reinstall a newly downloaded pms, add folders again. Reset you imac, Reset your apple tv. Post results.
OK - I will do this tonight before bed so it can scan my media overnight.
Yeah... right. The "?" was the question mark of my comment...
Also, it seems there are more bad characters slipped it to the 1st post - only one '/' between library and sections. Try...
http://127.0.0.1:32400/library/sections
and post back the outcome.
wahlman... do we really have to reinstall everything every couple of days?
You have a Mac, don't you?
:-D
Im some instances it has fixed errors. Just trying to help these guys troubleshoot :slight_smile: recently, personally no but i only use .mp4 files myself. Ive had issues with pms before not displaying content properly and by removing and readding the library it has solved my issues in the past. I dont know what kind of media he is using so it makes it difficult to troubleshoot with little info to go on.
Un-installing seems a little drastic to me and isnt really trouble-solving…i would a least try adding a new section with the new files to see if that comes through, however it seems strange that the media library see new content, but not PlexConnect…has the OP gone all the way out of Trailers and back in to refresh the connection?
Its not like it takes a long time to drag and drop an app and delete the config files. Not sure if he has or not, he was trying my suggestion to remove all media for pms then readding it, just trying to troubleshoot the issue by any means possible while not being physically at the atv/pms server obviously, this rules out quite a bit from being the source of the issue. Just looking to resolve this as quickly as possible.
Removing media etc mean PMS has to download and create the tags etc all over again for its database. PITA if you have to edit some files to get correct details.....If the Media center shows new files, the issue isnt with PMS and un-install & re-install will not reslove the issue.
If other clients can assess the new files, it would seem to me the issue lies with plex connect...
OP, are you running the https plexconnect or the early version, have you exited trailers and gone back in?
