No Items available and pms_uuid_not_found
After some problems with the DirectPlay with subtitles I decided to update the PlexConnect (to the last one downloaded from github) and Plex Media Server (0.9.8.6.175) on a Windows 7 machine.
Everything is well setuped and I tried several times. But still can't get it to work back again.
Once in trailers it looks that its does not discover de PMS. The PlexConnect console log shows 1 discovered, and after pressing on discover and afterwards "selecting" my PMS, instead of showing pms_uuid_not_found I go back to Library and I get a "No items available"
Any idea or update coming?
No idea... updates are coming. A lot. Don't know if the fix your issues, though. :-(
I have the same issue on my Apple TV 3. My media library is now showing up as no items available when I go into trailers, however it sees PMS perfectly fine.
Logg out the “*” user of MyPlex under settings and try again. Worked for me.
Logg out the "*" user of MyPlex under settings and try again. Worked for me.
Had the same yesterday, after I logged out of MyPlex under PlexConnect settings, my library came alive!
Same issue, same fix. Thanks!
Guys,
Newbie here.
I have my mediaserver and client al running on windows machines.
I can see my friends library on my tablet and on my windows machine but not in the apple tv.
Log out MyPlex?
Where can i find this setting?
Regards
Thomas
Oeps, scrolled over it.
Found it and it works <_<
This didn’t work for me. I’m getting this when it’s trying to discover the PMS:
22:33:15 PlexAPI: No Response from Plex Media Server 22:33:15 PlexAPI: We failed to reach a server. Reason: [Errno 8] nodename nor servname provided, or not known
router: DNS-Rebind-Protection?
