New library on remote pc
Server Version#: 1.23.2.4656
I am running my main server on a mac and everything is working fine.
I have a large amount of music on a different Windows-10 PC. Is it possible to add a second music library from a remote pc to my server running on the mac?
Yes. Just make sure to mount the Win10 device‘s media folder on your Mac. Then create your new library pointing to that folder.
You could even add that as a second folder to your existing music library.
I have turned on file sharing on the windows PC and have also shared the directory containing the music but I am unable to see the folder.
When I try to connect as guest from the mac I get an access denied message.
Thank you
