Hi
I have a little problem with Controllr:
If I have a TV-show split on two Hard-Drives, the show is twice in the Controllr.app. But in Plex its correct: there is it only once.
I have the TV-Show in the same source:
http://img375.imageshack.us/img375/131/20100729gu8sbte2qf1p3fg.th.jpg
Can I do anything?
I am still working on the next update of Controllr. My focus is on Plex 9 compatibility, so I will ensure the issues brought up here are addressed, specifically iTunes support, and multiple drive spanning.
While I have the podium, I would like you to try my latest app, Trackr. It is RSS reader and web browser allowing you to upload files to Dropbox, or download to your iPhone. So if you have some need to upload files to a watched Dropbox folder, you may find it useful. A few promo codes:
EYYTFK4F7ERJ
9RXTYAR9MM3M
F4XM3MPJ99TK
MAXRLJT4YYJ6
W3RRXFLML96K
NKYAEF7KTA4M
Please, do not discuss Trackr on this forum. Any questions, bug reports and suggestions should be entered on the page of my website, muzisoftware.com
[Lets keep the focus of this forum on Controllr.
http://dl.dropbox.com/u/1482060/Trackr%20PressKit/iPhone%20images/TrackrFrontpageSmall.png](itms://itunes.apple.com/us/app/trackr/id305665024?mt=8)http://dl.dropbox.com/u/1482060/Trackr%20PressKit/iPhone%20images/app-store.png
PS. Controllr price reduced to $1.99 for a limited time
absolete. sry can’t delete this.
Why when you have a lot movies files only read about 100 and dont show the other ones?
Well mate if your like me and you have to stay on 3.12 for a sim card unlock , Bigboss has a firmware spoofer on the cydia store free that toggles showing as 3.12.and 3.13 to itunes and all apps . controllr runs fine on my 3.12(3) =P
This is the first app I bought (since I don’t posses an ipad/iphone/ipod touch and wanted to test it). My ITunes account says, that I have payed for Controllr v1.0 (did this on an ipod touch), but when browsing to the app via Itunes I can only buy but not download it.
Could someone explain this please?
Whoa? It certainly does not, for me at least. Every time I load it up it has to re download all art, and takes forever. I was pretty excited about this app, having tried others with the same issue; but unfortunately without caching it's just not useful, at all...
Has anyone tried HD Remote for iPad? - just released to the store a few days ago, it looks promising. I'm on the fence about spending more money on yet another app that promises a lot but doesn't deliver for XBMC/Plex...
Just tried conrollr and love it. Works beautifully on my iPhone 4.
Can’t figure out why i can’t get this to work, shouldn’t be needed to add a port forward to the plex machine when accessing from inside the network?
i get the host can’t be reached error message, have tried restarting the machine
Btw. can’t access localip:3000
Very cool app, purchased it for my home entertainment systems. I have nearly 800 movies in my collection and many TV Shows. My only suggestion at this point is to offer some sort of cacheing for fanart. I wouldn’t mind having to initially scroll through all of my movies for it to grab all the album art. The slight annoyance I have is that when I quit the app, I have to re-load all of the fanart for the movies and TV Shows. Any possibility or thoughts on keeping this locally on the iDevice?
The next update will fix the image caching as well as work with Plex 9 and support the retina display of the iPhone 4.
Quick question:
would it be possible to launch Plex from this app when Plex is not running? After all, the webserver IS running? Would be great since now I have to manually start Plex for Controllr to work… which kinda sucks.
Hi
Back to my problem. I can see all the movies using the other interface but i cant play the movie from it. In controllr when i press the play button nothing happens. I have tried to download HD Remote and here i have the same problem. I can see all my movies but i cant start them.
Please help me someone :)
Seems like your library is out of sync. This could happen if your data was moved to another drive. Try going into the settings menu in Plex, go to Video, Library, then Clean Library...
See if that helps. If not, we can dig into your database file.
Hi turbolag,
thanks for pioneering this, but what is your view on the newly released Plex app? Does that make Controllr superflous or do you see those coexisting in a happy future?
Just curious.
The Plex iOS app is great as it allows streaming of all of your media. Controllr is better suited for controlling Plex from your sofa, and quickly navigating your media. There are more playback controls, such as a scrubber and volume control. Also, Controllr works with Plex 0.8 if you are still prefer it.
Personally, I use both apps, Controllr on the sofa and Plex for streaming.
Thanks for your answer. Good points.
turbolag, do you mind explaining what my problem may be?
i can see all my movies, tv shows, and music on my iphone but when i try to play any of them, I get a blank screen on the phone and nothing running in plex. I am using plex .9 and the latest version of controllr. When i play a movie in plex, i can see the movie thumb in the now playing screen on my iphone and can control it by fast forwarding/pause/rewinding/etc. i saw that another user had that problem as well and you recommended to “Try going into the settings menu in Plex, go to Video, Library, then Clean Library…” Can you do this in plex .9? I couldn’t find that option.
Any help would be great…thanks!
Old(ish) post, but is this app still being maintained? It doesn’t seem to jive with the latest version. I can scroll through my media on it, and control Plex itself, but movies do not play - it just sits at Opening Stream.
