Server Version#: 1.16.3.1402
Player Version#: 3.109.2 (Plex for Samsung) (Tizen 4.0)
The app is unable to show my local server on the Home Screen, despite the fact that I have my local server categories pinned on the side menu. While trying to customize the hubs on Home Screen, only one of my remote servers (I have two remote servers, and one local) is showed on the customize screen.
I want to be clear that I can access and play any media on all the three servers. My problem is that my Home Screen now always point to content on the server I use the least.
Is there any way to show all of my servers or at least to show my most used one instead of the one Plex randomly chose?
Do they show in the More menu? For any library. if you select the dots to the left o the library name. THere should be an option to manage hubs and pin a hub like Recently Added from TV library on server X to the home screen.
It definitely should have populated with libraries of the initial chose of the preferred server. Need to look into why your local server was not an option to start with to choose as the initial preferred.
There’s no such option, but I managed to find a workaround.
At the bottom of the Recommended section, instead of the Library, there’s an option to add to the hub. That did the trick partially, since only “On Deck” and “Recently Added” are available to the hub, not “Continue Watching”.
It would be better if the option is easier to find.
Restoring the Hub still set the hub only with the least used Library, and I have to redo the whole process by hand.
