Server Version#: 1.20.5.3551
Tuner Make/Model: HDHR Prime x 2
Hello, I have noticed that any new show that I schedule to record through the DVR/Live TV interface never matches correctly against TheTVDB or any other agent service.
I have to go in later and run a ‘Fix Match’, and typically search for the show.
Is there a reason why the shows are not matching correctly? Any shows added from sources outside of DVR/Live TV are working perfectly.
Could it be related to my agent setup?
I am also noticing that when added to my TV Shows library, these specific shows are defaulting the ‘Show Seasons’ setting to ‘hide’ instead of ‘Library Default’.
OK, I think this is now done intentionally for DVR content.
Because very often the EPG has different information than TheTVDB.
Sometimes it doesn’t have season or episode numbers.
Sometimes it uses a different episode number than TheTVDB.
Sometimes it doesn’t even mark a tv show as a show but as a movie.
thanks! I look forward to hearing if there are specific issues. Also, now that I have run a ‘Fix Match’, episodes are adding correctly, with all of the data. So it leads me to believe that the DVR episode data has enough correct info to be added/matched, just the initial episode creating the ‘Show’ is not matching/choosing the correct match…
