Nework streamers
I have a Cambridge Audio CXN but cant connect to it through the Plex App. It will play your library from computer or NAS just fine, but will not ‘push’ to the CXNwhich defeats the purpose of getting a high end streamer.
If you’re ok using the apps that come with your streamer, then you will be fine, but the Plex App is so much more polished and I’d prefer to use that.
Does anyone know of a workaround for this or will it be an option in the future?
Your devices uses DLNA. Plex cannot push to a DLNA client.
