Nginx Reverse Proxy for Subdomain
My setup
  • nginx 1.19.7
  • Plex server versions 1.21.3.4046 and 1.21.3.4021 (or higher, maybe lower)
  • Ubuntu 20.04 LTS
Requirements
  • nginx >1.17.0
  • nginx modules: --with-debug --with-cc-opt=-Wimplicit-fallthrough=0 --with-pcre=objs/lib/pcre-8.44 --with-zlib=objs/lib/zlib-1.2.11 --with-openssl-opt='no-asm no-tests' --with-file-aio --with-http_addition_module --with-http_auth_request_module --with-http_dav_module --with-http_degradation_module --with-http_flv_module --with-http_gunzip_module --with-http_gzip_static_module --with-http_image_filter_module --with-http_mp4_module --with-http_random_index_module --with-http_realip_module --with-http_secure_link_module --with-http_slice_module --with-http_ssl_module --with-http_stub_status_module --with-http_sub_module --with-http_v2_module --with-http_xslt_module --with-mail --with-mail_ssl_module --with-poll_module --with-select_module --with-stream --with-stream_ssl_module --with-stream_ssl_preread_module
A couple things worth mentioning:
  • Only use TLSv1.2 and TLSv1.3
  • Change ciphers accordingly
  • You don’t need the error_page section if you don’t want (but will tell you if Plex server isn’t running for some reason or another)
  • Add some security headers
  • Turn on SSL Session Cache
  • SSL Stapling (if don’t have a self-signed certificate)
  • Use upstream if you want (required nginx upstream module)
What this config enables on Plex
  • Can watch Live TV, Movies & Shows on Plex
  • Plays TV Show theme songs
  • Plays Movie trailers, extras, and featurettes
Finally
If you run into problems with images not displaying, media not playing, or something else that worked before, comment out the add_header Content-Security-Policy line and reload nginx and see if that helps.
plex.conf
upstream plex {
    server localhost:32400;
server {
    listen 443 ssl http2;
    server_name plex.domain.com;
    ssl_certificate /etc/nginx/ssl/cert.pem;
    ssl_certificate_key /etc/nginx/ssl/key.key;
    client_max_body_size 500M;
    send_timeout 100m;
    ssl_session_cache builtin:1000 shared:SSL:10m;
    ssl_protocols TLSv1.2 TLSv1.3;
    ssl_ciphers 'TLS-CHACHA20-POLY1305-SHA256:TLS-AES-256-GCM-SHA384:TLS-AES-128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256';
    ssl_stapling on;
    ssl_stapling_verify on;
    # For LetsEncrypt/Certbot, you can get your chain like this: https://esham.io/2016/01/ocsp-stapling
    ssl_trusted_certificate /path/to/intermediate/ocsp/cert-r3.pem;
    add_header Strict-Transport-Security max-age=15768000;
    add_header Referrer-Policy strict-origin-when-cross-origin;
    add_header X-Frame-Options deny;
    add_header X-Content-Type-Options nosniff;
    add_header X-XSS-Protection "1; mode=block";
    add_header Permissions-Policy "geolocation=(self), midi=(self), sync-xhr=(self), microphone=(self), camera=(self), magnetometer=(self), gyroscope=(self), fullscreen=(self), payment=(self)";
    # Pay attention to how many domains we need to allow
    add_header Content-Security-Policy "default-src 'none'; base-uri 'self' plex.domain.com; font-src 'self' data: plex.domain.com; media-src 'self' data: blob: plex.domain.com https://*.plex.direct:32400 https://video.internetvideoarchive.net https://*.cloudfront.net; script-src 'self' 'unsafe-inline' 'unsafe-eval' domain.com plex.domain.com; style-src 'self' 'unsafe-inline' plex.domain.com; img-src 'self' data: blob: https: plex.domain.com; worker-src * blob:; frame-src 'self'; connect-src 'self' https: domain.com plex.domain.com wss://*.plex.direct:32400 wss://pubsub.plex.tv; object-src 'self' plex.domain.com; frame-ancestors 'self' domain.com plex.domain.com; form-action 'self' plex.domain.com; manifest-src 'self' plex.domain.com; script-src-elem 'self' 'unsafe-inline' domain.com plex.domain.com www.gstatic.com";
    error_page 500 502 503 504 /50x.html;
        location = /50x.html {
        root /path/to/503;
    # gzip source: https://github.com/toomuchio/plex-nginx-reverseproxy/blob/master/nginx.conf
    # Plex has A LOT of javascript, xml and html. This helps a lot, but if it causes playback issues with devices, disable this section
    gzip on;
    gzip_vary on;
    gzip_min_length 1000;
    gzip_proxied any;
    gzip_types text/plain text/css text/xml application/xml text/javascript application/x-javascript image/svg+xml;
    gzip_disable "MSIE [1-6]\.";
    # Forward real ip and host to Plex
    proxy_set_header Host $host;
    proxy_set_header X-Real-IP $remote_addr;
    # If not using ngx_http_realip_module change '$http_x_forwarded_for,$realip_remote_addr' to $proxy_add_x_forwarded_for
    proxy_set_header X-Forwarded-For '$proxy_add_x_forwarded_for,$realip_remote_addr';
    proxy_set_header X-Forwarded-Proto $scheme;
    proxy_set_header Sec-WebSocket-Extensions $http_sec_websocket_extensions;
    proxy_set_header Sec-WebSocket-Key $http_sec_websocket_key;
    proxy_set_header Sec-WebSocket-Version $http_sec_websocket_version;
    # Disables compression between Plex and Nginx, required if using sub_filter below.
    # May also improve loading time by a very marginal amount, as nginx will compress anyway.
    #proxy_set_header Accept-Encoding "";
    # Buffering off send to the client as soon as the data is received from Plex.
    proxy_redirect off;
    proxy_buffering off;
    location / {
        proxy_pass http://plex/;
        proxy_set_header X-Forwarded-For $remote_addr;
        proxy_ssl_verify off;
        proxy_http_version 1.1;
        proxy_set_header Host $http_host;
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "upgrade";
        proxy_read_timeout 86400;
Need Plex for a URL subpath?
Change to this:
location /plex/ {
Other notes
  • This reverse proxy, but for apache is here.
  • Using nginx with Plex is lightening fast.
  • Have more than one Plex server? Try this for some load balancing:
upstream plex {
    server localhost:32400 weight=5;
    server 192.168.1.22:32400 max_conns=2;
Neat. Does this work with most clients, do you know?
Why do you set this? Image/video uploads, I’m guessing?
And that? That’s so long.
And this one. I’d have guessed this would be harmful.
As far as I know, this should work with lot’s of modern clients because of the newer security protocols.
I do user Plex for video uploads from my iPhone. A 60 second 1080p 60fps video is approximately 100MB. This is the reason my client_max_body_size is set so high. You may adjust this to something way more reasonable if you do not use that functionality for Plex.
“Some players don’t reopen a socket and playback stops totally instead of resuming after an extended pause i.e. Chrome”. This was taken directly from this source. So, if I interpret that correctly, if you watch a two hour movie, in theory, it might stop playing.
The proxy_buffering set to off tells nginx to immediately send the data to and from Plex rather than adding overhead between the client and the server.
