There is no way that I can find to go up a folder on Plex Web. You can click the library name and go to the root directory but I don’t want to do that if I’m several levels deep. I can use the browser native forward/back but that doesn’t always work and there really should be a button to go back and also a path bar that shows what folder you are in (similar to finder/explorer/any folder navigator).
Server Version#: 1.24.0.4930
