No Audio Detected - Direct Play/Changes Default Playback Settings
Certain movies and shows won’t play with direct play normally. As soon as the video loads it gives a No Audio Detected message and asks if I want to disable direct play. Once I do that it plays fine. Anyone know how to fix this so I don’t have to change the playback setting?
Also if I select Yes when it prompts me to disable direct play it doesn’t just temporarily change the setting for the current video I am on like it used to. It changes it to Auto in my playback settings for all videos.
Before If a setting was changed for a particular video it would only affect that video and no others, and if I backed out and went into the same video it would revert to what my settings are saved as. Now it keeps changing it to Auto for the videos that won’t detect audio and I have to go back to the playback settings and select Forced again after I’m done.
This is really annoying!
