No Audio from Logitech G930
I currently have a Pi2 plugged into a receiver via HDMI running Rasplex 0.7.1. I thought it would be cool if I could use my G930 headset if I ever wanted to watch something without making a ton of noise. I plugged in the USB dongle and restarted the pi. Rasplex seems to acknowledge it by naming it specifically in my audio output and passthrough devices, but I haven’t managed to find a combination of settings that will allow it to play audio. The receiver continues to produce sound, even with the G930 selected. What did I miss? Do I need to install additional drivers?
I forgot to mention that I do get system sounds through the headset, but not content audio.
You will only get music at the moment - no audio from video content.
Regards
You are correct, sir. Thank you. Hopefully it wont be too much longer till I can hear everything.
