I have a WinTV-dualHD and is running Ubuntu 16.04 and have installed the drivers as stated on http://www.hauppauge.com/site/support/linux.html and also the firmware as this is a DVB-T device
lsusb show
Bus 001 Device 003: ID 2040:0265 Hauppauge
I have looked at https://www.linuxtv.org/wiki/index.php/Hauppauge_WinTV-dualHD and this show is is the 01590 modem. All should be good.
lsdvb also show the devices
lsdvb: Simple utility to list PCI/PCIe DVB devices
Version: 0.0.4
Copyright (C) Manu Abraham
em28xx (-2041695032:32764 -2095088865:32618) on PCI Domain:1 Bus:0 Device:-2092885488 Function:32618
DEVICE:0 ADAPTER:0 FRONTEND:4 (Silicon Labs Si2168)
FE_OFDM Fmin=42MHz Fmax=870MHz
DEVICE:0 ADAPTER:1 FRONTEND:4 (Silicon Labs Si2168)
Plex is also member of the video group
id plex
uid=111(plex) gid=117(plex) groups=117(plex),44(video)
If I try to setup the device in plex it see the device, but when I scan it does not find any channels. I tried the device on a Nvidia Shield also - same problem. I then installed a test windows plex and same problem. I then installed the WinTV application on the windows device and then plex could find channel.
But I would like to use the tuner with my Ubuntu Plex server.
I tried to search for channel with w_scan and it seems to find channels - but then delete them again. Output
538000: (time: 00:32.496) signal ok: QAM_AUTO f = 538000 kHz I999B8C999D999T999G999Y999 (0:0:0)
Info: no data from PAT after 2 seconds
deleting (QAM_AUTO f = 538000 kHz I999B8C999D999T999G999Y999 (0:0:0))
I have been unable to find the solution to this problem and would like some help.
Br.
Jan
