No connection to server, "Connection refused" when accessing web app
Server Version#: 1.18.2.2058-e67a4e892 armhf
Player Version#: All
Everything was working fine, then one day I was not able to access the server from any player. I am also not able to access the web app either on the server device (Raspberry pi 3B+ running Raspbian) or from another device using the pi’s IP address.
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.5.log says the following:
WARN - NetworkServiceBrowser: Error sending out discover packet from 127.0.0.1 to 127.255.255.255: Operation not permitted
Your network adapter isn’t working.
You should have something on 192.168.x.x, 10.x.x.x, or 172.16.x.x -> 172.31.x.x
Ok, how can I fix that?
I found the solution.
delete (or rename) the Plex Preferences.xml file located at /var/lib/plexmediaserver/Library/Application Support/Plex Media Server,
run:
sudo systemctl restart plexmediaserver
and voila, I was able to access the web app, run the setup wizard, and get going.
