No content showing on any client
Server Version#: 1.41.6.9685
Player Version#: 2024.14.0 (1037)
Running Plex Server as a Docker Container on Ubuntu Server. Recently set up a new server. All my clients connected to the old instance OK. Ever since I set up the new server all clients are showing No Content. However, when I go into the Web App I see all my content.
What I tried so far:
  • Updated and restartet the server and client apps
  • Deleted and re-installed client apps
  • Secure connections set to „preferred“
  • Network access/permissions
  • Checked media library and permissions
Anything else I can try to fix it?
need more details as to your port settings. So you’re running two PMS instances on the same machine right? When you go to the web app, how do you know which instance you’re connecting to?
I’m guessing that you’re just confusing the two instances. Plex only listens to port 32400 on the local machine or inside docker, so you have to handle that manually.
sorry, I wasn‘t clear about that. I‘m only running 1 PMS instance. Recently moved it to a new machine. When I had the old machine running, all my local clients had access to my library (haven‘t shared it outside my local network yet).
In the meantime I set up remote access with port forwarding. Now I see my library in Infuse but iOS and iPad App still does not show any content.
Is this still under the same account? Did you claim the new server?
yes, same account and the server is claimed. Everything seems to be working fine now except for the iOS Apps
Okay check on your account if there are two servers. You have to remove the old server if it’s still there. I’m thinking your iOS apps are selecting the old server.
there is only 1 server, which is the right one
Are you sure your server is accessible remotely? Check if 32400 is pingable. I’m thinking maybe your iOS devices are using the internet to connect to your server? Open Port Check Tool - Test Port Forwarding on Your Router
It’s hard for me to know because I can’t see the iOS screen. There’s no error on your iOS apps? It just shows an empty library? Can you even see your libraries?
Port forwarding works but both my iPhone and iPad are on the same local network as the server.
The apps are showing my 2 libraries but once I click one of them it‘s just a loading screen
After dozens of re-installs and re-sign ins I finally got it working.
Thank you Christian for trying to help me.
