hi Guys,
i just installed on one of my rasps rasplex.
Just tried it at the 256mb ram version, it is not performing well but it is okay.
The software find my server but it doesn't show all covers.
Please see the picture.
](http://imageshack.us/photo/my-images/853/ai24.jpg/)
Did i do anything wrong?
BR Robert
Anybody can help me?
I just tried also my 512MB RAM PI with the same problem.
Also a new installation on the pi was with the same result.
I'm running the newest version of plex server on my ubuntu system (12.04 lts on xen).
But on one folder it shows the cover. Here are some movies inside.
The second folder with th shows is without any covers.
Cant understand the problem.
Be patient and let i load as much as it can in the cashe first.
hi Guys,
BR Robert
Access your plex server using the web console. Do you see the covers and art on the server? if not, that means your plex server does not recognize the files as the metadata is incomplete or wrong. Or maybe just doing a deep refresh will solve it in many cases.
On the Web Interface of the sever are all Covers shown
I will try it with the deep search
So the deep search did not help.
If i understand right plex is based on xbmc?
I had allready tested openelec on my 256mb and 512mb PI and sorry it was running much better then rasplex.
Also had a shared database installed, mysql on my private server in the basement and a lithe bit of configuration on the setting files.
And it works well.
Rasplex need more time to grow up.
