Hiboser
1
Was told Dolby Vision should work on the XBOX Series X but I only get HDR10.
Any advice?
Check the Dolby Vision profile via Get Info (or analyze the file with MediaInfo).
Per the release notes, only DV profiles 4 & 5 are supported.
Is it ever going to support profile 7 like the ShieldTV does? Is there something technical holding this back?
