No entries found at start
Hi!
I have set up a Plex Server on my Synology DS220+. Everything works fine, but since a month I get the Error “No entries found. The Folder seems to be empty.” at the start of the Plex App on my Nvidia Shield Pro. A second later I can see everything popping up on the left column. I just have to press back on my remote and go to tv shows or movies and everything is there! Im connected locally without any problems. I already tried to uninstall and install the Player and the server ( even with an older version) but the problem remains. Can anybody help me?
I think the player timeouts too fast before the server can send all the information.
Server Version#: 1.30.1.6562
Player Version#: 9.13.1.37459
Known problem.
Should be fixed in the latest Android TV beta.
You can sideload if desired. You want the arm64v8a version for the Shield Pro.
WOW, thanks for the quick help!
