No images on Live TV Guide
Server Version#: 1.27.0.5897
Player Version#: 4.83.2
Tuner Make/Model: Vbox TV Gateway 4134
Guide/Lineup name:
Using XMLTV?: Yes
Channel number/Name:
I’m sorry if this has been covered and resolved before, I’m not able to find it if it has.
I have recently installed the VBox Satellite gateway. This box works fine and I’ve added it to plex.
The shows play as expected but I do not have ANY channel images. It’s difficult to work out what channel is which.
I can’t see how I can add the channel images to the guide.
All images show in the DVR settings page.
Any help would be greatly appreciated.
Those pics will have to come from your XMLTV file. If it contains no or invalid links, you get no station logos.
Thanks for the quick reply OttoKerner.
I specified the XMLTV file on the VBox which has that data. I’ll try again but not specify the xml on the vbox and see where that takes me.
I don’t know this device. I’m not sure the file is accessible to Plex server. Particularly if it’s only accessible by SMB file share or if it’s protected by access credentials.
This is the interface.
Since the web app is loaded per https, your web browser may refuse all content which is not available per https.
But I don’t know if that is really the case.
I’d experiment with replaing the domain name with the local IP of the vbox. At least for the logos path.
