Station logos not showing
I have noticed recently that my live tv is not showing station logos for any of my IPTV channels but works fine for my HDHomerun channels. i am using xmltv files generated by schedulesdirect for both hdhr and iptv (xteve) but only difference is that for HDHR it is pulling direct from an xml file generated using EPG123 and for the IPTV channels xteve is using the same xml file from EPG123 and then xteve is generating the xml file that goes with it’s channel mapping.
Now i would normally presume that xteve isnt adding the channel logos except that if i use an IPTV player to connect directly to xteve all te channels show with guide and the logos so it must be a plex thing.
Any suggestions how I can get the logos back for my IPTV channels in Plex?
