Hi All,
Been running PMS and PC on a Mac Mini with no issues so far - Mini was on SL 10.6.8 but starting to grind down. Got a new Mac Mini 2014 with Yosemite and was able to successfully transfer the PMS and HT and all works fine except when I came to PC. When accessed, I get No Library Available Error (similarly no playlists or channels available). Under settings, it does discover the PMS server and I have also tried to put the IP directly in the settings cfg file but no luck.
Any thoughts would be helpful please. It does run and access the PC on the server but no luck getting it to go. I am on ATV 3 with 7.0x for SW. Like I said, it works on the older Mac but not on this one. The older one is running PC 0.4 but this AM when I downloaded the latest from PC Wiki it gave me 0.5.
Thanks so much and I have attached the log file below.
PG.
I have read through this twice and I am not sure I get what you're saying, are you saying you had an old mini running PMS, you migrated to a new mini, and that PMS seems to work just fine but PHT on that same machine wont find the server?
First of all you need to uninstall 0.5-dev and install 0.5 instead. See this post.
Have you copied the certs from the old macmini to the new one ?
Do you see your library on PlexWeb ?
You can try other themes (github's) for now using the OpenPlex.app (in my signature) or git clone or download them manually until the issue(s) are resolved as @moody_blue told you for the official iBaa theme (github).
@All
Thanks for the suggestions - I reverted back to 0.5 and now seeing a different behaviour... I think I may have been seeing the library running on the old mac mini and for some reason even after following https://support.plex.tv/hc/en-us/articles/201370363-Move-an-Install-to-Another-System it still doesn't show up on the new one.
Going to try to resolve that and I will provide an update when done. Anyone seen this issue that copying from one system to another, libraries don't show up?
PG
It seems that the database (or the files) when I zipped it from the source computer were either corrupt or didn't copy completely. Re-zipped again from source, brought it over and now running on PC 0.5 and it all seem to behave correctly. Thanks @moody_blue for the suggestions as it led me to pay more attention to the libaries not coming through over plex web properly...
-pg
