No local album art showing
I’ve read a lot of the posts on this topic, but I’m really flummoxed over this. I have many albums. Using MP3Tag, I have manually edited all of the meta data, including the album art.
For the Library (Advanced) settings, I use the Plex Music Scanner and for agent, I’ve tried Plex Music and Personal Media Artists. I have checked Prefer Local Metadata and for Album Art, I have selected Local Files Only. According to MP3Tag, the cover art is listed as Front Cover.
When I refresh metadata, all but 3 show no album art, and I cannot figure out what makes those 3 so special. All of the art is embedded in each track and it doesn’t seem to matter if I have a cover.jpg file in the album folder. The 3 that work do not have that file.
Most or all of them do get their covers when I do not prefer local metadata, but mine are better. :slight_smile:
I’d appreciate any suggestions anyone might suggest!
Have you considered placing those album covers as local files alongside the music files? Given there’s usually 1 album cover per album, there’s little value add to have them added inside each track.
This should work the same way as for movies/shows, by placing a file called e.g. cover.jpg into the album folder.
Tom, I understand your point. Even though I’ve been a Plex user for over a decade, I still sometimes play the music through other players. To be safe (cover art-wise) I just include the image with each file. I save them such that compared to the FLAC files they’re attached to, their additional storage consumption is negligible.
Also, I have tried your suggestion as a means to remedy the overall problem of the album art not displaying and it didn’t help. I’ve named the stand-alone files cover.jpg and folder.jpg. No joy.
I originally posted that I had tried setting the library to Personal Media Artists, and I had, without success. But overnight, that seems to have done the trick. All my art is displaying.
So my current settings are Plex Scanner, Personal Media Artists, and Local Files Only. I hope that helps anyone else with this problem.
