No module named plexconnect
Hi All,
Before posting I searched google and as well this forum and no where I could find an post describing how to resolve below error. Therefore I am posting the issues and seeking your help. I am getting this No module named plexconnect and unable to get it started.
Thanks in advance for your help !
C:\Temp\PlexC\PlexConnect-XML_templates>C:\Python27\python plexconnect.py
21:02:45 PlexConnect: started: 21:02:45
21:02:45 PlexConnect: ***
21:02:45 PlexConnect: PlexConnect
21:02:45 PlexConnect: Press ENTER to shut down.
21:02:45 Settings: add section PlexConnect
21:02:45 Settings: add option port_pms=32400
21:02:45 Settings: add option enable_plexgdm=True
21:02:45 Settings: add option ip_dnsmaster=192.168.1.14
21:02:45 Settings: add option ip_webserver=0.0.0.0
21:02:45 Settings: add option loglevel=Normal
21:02:45 Settings: add option enable_dnsserver=True
21:02:45 Settings: add option ip_pms=192.168.1.14
21:02:45 Settings: add option port_webserver=80
21:02:45 PlexConnect: IP_self: 192.168.1.14
Traceback (most recent call last):
  File "", line 1, in
  File "C:\Python27\lib\multiprocessing\forking.py", line 380, in main
    prepare(preparation_data)
  File "C:\Python27\lib\multiprocessing\forking.py", line 489, in prepare
    file, path_name, etc = imp.find_module(main_name, dirs)
ImportError: No module named plexconnect
21:02:45 PlexConnect: DNSServer not alive. Shutting down.
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV3 running 5.2
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.14
  • The device and operating system (including version number) that PlexConnect is installed on: PC Windows 7
  • The local IP address of the device that PlexConnect is installed on: 192.168.1.14
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on:  PC Windows 7
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.14
  • Where your media is stored (e.g. internal drive): None
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. The latest from this link in the wiki https://github.com/i...L_templates.zip downloaded 2013-Jul-02
  • The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_pms = 192.168.1.14
ip_dnsmaster = 8.8.8.8  (I tried with 192.168.1.1 & 192.168.1.14 as well, same results)
enable_dnsserver = True
If I use the PlexConnect-0.1-iOS-pre5.1 based install set I get the below error
C:\Python27\PlexConnect-0.1-iOS-pre5.1>C:\Python27\python plexconnect.py
21:36:26 PlexConnect: started: 21:36:26
21:36:26 PlexConnect: ***
21:36:26 PlexConnect: PlexConnect
21:36:26 PlexConnect: Press ENTER to shut down.
21:36:26 PlexConnect: IP_self: 192.168.1.14
21:36:26 PlexGDM: ***
21:36:26 PlexGDM: looking up Plex Media Server
21:36:27 PlexGDM: servers discovered: 1
21:36:27 PlexConnect: PMS: 192.168.1.14:32400
  File "", line 1, in
21:36:27 PlexConnect: DNSServer not alive. Shutting down.
You haven't set the IP of the webserver in the settings file, I don't think that would cause this issue, but may cause other issues.
Edit: And just to confirm, you have all the PlexConnect files stored in the same folder?
That is throwing me off for some reason, what is the location of the PlexConnect files?
Edit: Ah I get it I think, the PlexConnect files are stored at C:\Temp\PlexC and Python installed/running from C:\python27
ip_webserver = 0.0.0.0 is fine - as long as you don't have the need to bind a specific IP.
ADD:
Do you need to run python specifying the path (C:\python27\)? Any chance to put that into your PATH?
