I am really loving this app, and hope to see more updates, but it has been almost 6 months since the last one. I hope this project isn’t dead.
Sounds wrong… I’ve only received an update about 2-4 weeks ago. Where/how did you check?
Last update was version 1.0.5 and that was in April.
I’ve only used PlexAmp on my Mac so far… there I’ve got an option to manually check for updates in the menu / task bar. Can you trigger that on your setup too?
Same, I’m using it on my Mac, and I just tried that and it says I already have the latest version.
Which version of macOS do you have installed?
Mojave 10.14.1
Version 1.0.5 is the latest publicly available version right now.
There is a 1.0.6 which will be available before long, just fighting some CI issues and distracted with a few other things
Plexamp is really wonderful !
However, please add
- Offer LUFS choice between -18 LUFS to -14 LUFS
- Add a clip limiter
Thanks !
3rik
Yay, Plexamp 1.1.0 is out! Is there an update log that will tell us what’s new, fixed, added, etc?
